Cleaning the intercooler
My AWIC arrived today, and one thing I noticed was a decent coating of oil on the intercooler. I'd like to clean it, however I'd like some opinions whether others have cleaned their intercooler, be it A/A or A/W, and with what.
TIA.
TIA.
Alcohol.
I just dumped a bunch in, and shook up the IC and drained it. I repeated until it was clear. Seemed to work pretty well.
did some searching on nabisco. Brake cleaner seems to be the way to go, and I will agree.....it's great stuff.....I really need to buy stock in it. I use it for everythng
Thanks guys.
Thanks guys.
I say alcohol too. Cap off one of the fittings and pour alcohol into the other. Cap that one off too, and shake shake shake. When you pour it out it'll be all dark and icky. You can do it a second time if you like; you'll hopefully see it come out much cleaner.
Yea, remember, alcohol is cheap by the gallon. Brake parts cleaner, 1 can would cost more than a gallon of alcohol.
I used hot water and detergent quite a few times. Then dried it out fairly well. Not so toxic that way.
It's this industrial cleaner stuff. Pretty cool, kind of a harsh detergent.
what type of alcohol are you guys talking about.....?
I just used rubbing alcohol. At the local dollar store there were little 16oz bottles of 70% isopropanol, 2 for a dollar. I think four of them filled a Saab intercooler.
If the intercooler is all metal, methanol or ethanol would probably be fine too. It's certainly easier to find them in undiluted form than it is to find isopropanol undiluted (the only common source I know of is Iso-HEET gas line antifreeze, but that's expensive).
Absolut
Legacy Central
rubbing alcohol will not work as well brake cleaner as a degreaser. Not really sure about ethanol or methanol.
Cleaned the intercooler up today.....used about two cans of brake cleaner. I think it worked out pretty good.
I found that the hose opening on the craftsman shop vac I have fits over the intake pipe of the intercooler. So I reversed the flow and blew air through the intercooler. The shop vac didn't even bog at all when I hooked it up.....so I guess that's a good sign in terms of pressure drop.
I ran water through the other portion of the intercooler to flush things out.
Also, just an FYI, the water portion of the intercooler takes just about 3 cups of water.....I'm not sure if that will be useful in sizing the radiator or pump, but hey, at least I got it.
I use brake cleaner for alot of stuff, we buy it in bulk, put it in cans then pressurize em w/ air.
But I cleaned my IC w/ carb cleaner.
brake solvent is tough on plastic and other stuff, my saab ic has plastic end caps.
I just sprayed it in, shook it around, turned it this way, turned it that way, put my left foot out.....thats what its all about!
Goodbye my sweet, parting is such sweet sorrow....1993 BC6 , Saab IC, with xtras Hallman MBC, HKS FCD , wrx exaust.
If you're not afraid you could heat the alcohol a bit in a microwave. I don't suggest doing it unless you're a very attentive person. Definitely don't use an open flame or a micro that has scratches on the inside. Isopopyl isn't too explosive but it is caustic. Anyway, when it's hot it cleans quite a bit better. Probably not for the faint of heart.
--Scott--
1991 - Rio Red SS
1991 - Rio Red SS
I know I sure the hell wouldn't do it
