need supplier for connectors
does anyone know where the 3mm female quick disconnects can be purchased? these are the ones used on the injectors and about everything else under the hood. they have a long tail that folds over on the little rubber sealant boots then the whole thing snaps inside the connectors housings. this is very similar to a gm quick disconnect...only smaller. i am trying to rewire all injectors and such and i dont want to splice in new wire if it can be helped, i would rather go with new wire all the way from injector coupling to harness coupling. and no the .110fqd do not have the tail on them
or else i would be in business. i am about halfway thru the wiring job on the firewall side and hopefully will be able to get the rest of this done soon!!! i hate being without this car
