New to Legacy Central
My lastest Subaru...I've finally made it out of the 80's...I've been in a time warp. 92 Legacy Sport Sedan Auto...$100.00...won't start...coolant on plugs. Never heard engine run, would you buy used engine or try to fix existing. I think it has blown head gasket or warped heads, cause there is coolant on all 4 plugs. Kid I bought it off of said he had bubble in resevoir, but then his brother drove it last winter & it died on him...hasn't started since. Any feedback would be greatly appreciated.
http://home.uplink.net/~mjseidel/LTBody.jpg
http://home.uplink.net/~mjseidel/LTEngine.jpg
http://home.uplink.net/~mjseidel/LTInt.jpg
http://home.uplink.net/~mjseidel/LTMiles.jpg
84 twagon
WRX guys would drool
Brat4by4: Why would WRX guys want these ej22t heads? My poll so far has indicated that I should buy a used engine.
84 twagon
don't get it
I still don't get it. Why would they want an old motor over there brand new 2.0 litre & what does closed deck mean
84 twagon
84 twagon
Check out the tech articles at www.legacycentral.org Basically the EJ22T is the toughest engine Subaru has ever made. WRX guys drool over it because it has potential much, much higher than their EJ20T and more displacement. Closed deck is explained in one of the tech articles on there. Read that and if you have questions post em!
Note: Even new STI 2.5 L engine is only semi-closed deck. Look at www.i-speed.com products page and their $4650 engine package is probably a built up EJ22T block. And their 2.4 L block could be a bored EJ22 block? Their Mofo on the other hand is just sweet.
Grant Hughes
Denver, CO
http://www.nocoastmotorsports.net
Denver, CO
I had coolant in two spark plugs holes (with the spark plugs still in of course) The engine wouldn't run.
Why? 'cause the fluid was shorting spark's high voltage onto the engine block.
How did the fluid get there? from a leaking reservoir that's close/above the left side pair of plugs...
Once I replaced the res. and drained the fluid from the plug holes the engine run w/out loosing a beat.
'92 Black Legacy Turbo - drove it out to Seattle
'91 White Legacy Turbo - drove it out to Argentina: [url]http://www.rallyexpedition.info[/url]
The i-Speed guys are indeed using a 2.2L block for those packages. They're not bored, but rather stroked 2.2T blocks. They're amazing too!
I'd get a used engine since you've got all the wiring and such intact. It'll allow you to work on it at your leisure and then when you're ready, it'll drop in with little complications.
-Brian
-Brian
'04 PSM FXT
