Saturday-
I was driving to my dads shop, and i see that my car is almost overheating, i manage to get to the shop and check it out, there is not much coolant so i go to put some in (i've been having troubles with my brand-new radiator) and it just starts dripping out. since the shop is busy i have to work on the car around back, so i take the radiator out, and we test it, it checks out. the lower radiator hose looked a little bad, so i replaced it. while its all apart, i decide to take off the a/c system just because. so i reasemble everything and start to fill it up and it just starts dripping out of the damn radiator again. so i take it all apart again and after further inspection we realize the radiator endtank is leaking (endtank was crooked and didnt seal right from the factory) so we took it off and resealed it, i put it back together and drove to work. end of crisis one of the weekend.
Sunday:
so i'm driving to church, coast in neutral to a stopsign, light turns green and i put it in drive and start to go. but as i'm going there is this sudden lurch and a loud clunk noise, i think "well, that was wierd....." but it works fine, so i keep on going and get there fine. but on my way home, i do the same coast in neutral to a stop sign and stop, put it in drive, and start to go, the wheels give a little chirp, then there is this god awful clunking and shuddering, so i put it in neutral as i'm still rolling and pull off to the side of the road, i put it in drive, to see what happens, and it moves a little and then goes CLUNK. right about now i'm thinking "shit, something else broke" so i call my dad and we tow my car to the shop, put it in the air and drain the front dif. fluid, and broken off teeth of my pinion shaft fall into the bucket. about now i'm thinking "looks like i'm getting my 5speed earlier than planned" not. we put the plug back in and go home so i can mourn the death of my front differential (broke 8 teeth off of the pinion shaft and 1 off of the differential)
Monday:
Fixed the tranny. basically we took parts from a 96 legacy LS tranny we had and used parts from my transmission to make a working tranny, but the gear ratio in the 96 was a 4.11 not a 3.9, so the rear diff has to be changed (bye-bye VLSD) in goes the open 4.11
CN: radiator broke on saturday and i fixed it, also removed a/c. transmission broke on sunday. fixed tranny on monday, but gear ratio changed to 4.11 and lost rear VLSD, also fixed awd
