So I started kinda eyeballing the scangauge info system thingy.. which reads off OBDII and says all kinds of goodies like
<block>
# Fuel Economy (MPG - gasoline engines only)
# Fuel Rate (GPH - gasoline engines only)
# Battery Voltage
# Coolant Temperature
# Intake Air Temperature
# Engine Speed (RPM)
# Vehicle speed (MPH)
# Manifold Pressure (not available on some vehicles)
# Engine Load
# Throttle Position
# Ignition Timing
# Open/Closed Loop
</block>
and damn! I want that! I can't afford it, but still. Does anyone make something like that which would hook up (even if haphazardly) to my 93 Legacy?
Data system for OBD1 cars?
gustavohuber
ex-devastated ex-owner of the $5500 parts car!
gustavohuber
