Heres my Saab IC setup and my new custom IC tube
Posted: Wed Apr 27, 2005 8:57 pm
by kidwired
I got my saab 900 IC at pick n pull, guy thought it was a heater core $15, while there I grabbed a bunch of IC hoses ans tubes from Saab, BMW and volvos, an armload of tubes and connectors $30.
I fitted everything up... then took one of my (alum) tubes to a shop, had it cut, flared and a bov tube welded on. $35
So I've got $80 in my IC.
Gotta run and pick up a silicone 90 and some 3/4 for bov this afternoon.
Posted: Thu Apr 28, 2005 1:57 am
by kidwired
its in, it works but I"m not entirely happy w/ the bov setup. it's got a loop deloo. Ashorter adapter at the ic inlet would solve the problem.
Anyone know the saab ic dia?
the turbo outlet is 1.75 I guess.
I searched but really didnt find anything and I need to get started on the "honey do" list so cant keep data mining.
Posted: Thu Apr 28, 2005 6:30 am
The turbo's compressor outlet outer diameter is about 1.75", yes. The intercooler's fittings have an outer diameter of about 2.25".
Posted: Thu Apr 28, 2005 7:14 am
by kidwired
2.25? looks bigger.
Posted: Thu Apr 28, 2005 12:10 pm
by dzx
Soon you'll be able to turn the boost up.
Posted: Thu Apr 28, 2005 12:25 pm
kidwired wrote:2.25? looks bigger.
It's not. Not by much, anyway... I'm using 2.25" couplers with mine.
Posted: Thu Apr 28, 2005 1:46 pm
by free5ty1e
it's more 2.25" than 2.5" -- you can fit 2.25" couplers over those pipes snugly. 2.5" is way too loose for the Saab 900 IC.
Stock turbo compressor outlet is 1.75", yes.
T-bird turbo compressor outlet is about 2"
TB is 2.75"
As always, I recommend stopping by a Central or Napa auto parts and asking to look through their formed radiator hoses - easy to cannibalize for specific bends and turns and such. Then again, I needed a bit more piping...
Posted: Thu Apr 28, 2005 9:45 pm
by Tleg93
Good pic, I've been wondering about this pipe and the picture says is all.
Posted: Fri Apr 29, 2005 2:32 am
by kidwired
Ideally the tube adapter to IC inlet should be shorter, alloing you to move the 3/4 stub farther up. Giving you more room for the BOV. and it should be a 90 pointing towards the bov connector on the intake tube. I think anyway.
