I got my saab 900 IC at pick n pull, guy thought it was a heater core $15, while there I grabbed a bunch of IC hoses ans tubes from Saab, BMW and volvos, an armload of tubes and connectors $30.
I fitted everything up... then took one of my (alum) tubes to a shop, had it cut, flared and a bov tube welded on. $35
So I've got $80 in my IC.
Gotta run and pick up a silicone 90 and some 3/4 for bov this afternoon.
Goodbye my sweet, parting is such sweet sorrow....1993 BC6 , Saab IC, with xtras Hallman MBC, HKS FCD , wrx exaust.
it's more 2.25" than 2.5" -- you can fit 2.25" couplers over those pipes snugly. 2.5" is way too loose for the Saab 900 IC.
Stock turbo compressor outlet is 1.75", yes.
T-bird turbo compressor outlet is about 2"
TB is 2.75"
As always, I recommend stopping by a Central or Napa auto parts and asking to look through their formed radiator hoses - easy to cannibalize for specific bends and turns and such. Then again, I needed a bit more piping...
-Chris
91SS 4EAT stock, 200k mi
Ideally the tube adapter to IC inlet should be shorter, alloing you to move the 3/4 stub farther up. Giving you more room for the BOV. and it should be a 90 pointing towards the bov connector on the intake tube. I think anyway.
