Can you safely hone the cylinders w/out cracking the blocK?
douglas vincent
Post by douglas vincent »
When I yank the engine again due to damaging the pistons or ring lands, I would like to actually hone the cylinders properly this time. I don't want to replace the bearings as I have had no problems or indications they are in bad shape, so I would rather not take that step of cracking and replacing.
