Issues with washing the engine bay...
LaureltheQueen
- Spelling Nazi
I washed my engine bay last year, and at the same time, a friend with a ej22 swapped 82 wagon did the same. After starting them up post-detail, they had lots of issues idling, and would even die. We blew out the spark plug sockets really well with some compressed air, and that seemed to fix the problem for the most part. 30 minutes of idling fixed the rest. I've since packed a fair bit of dielectric grease into the spark plug boots.
Has anyone had this problem? I figured it may be a quirky ej22 thing where the angle is an issue, or if we were just morons doing it. Thanks
Laurel Tuning Stage 15
92 Touring Wagon 5MT 16G
LaureltheQueen
- Spelling Nazi
- quasi-mod-o
I wonder if the TPS sensor gets wet and fucks up the idle, since the idle switch is built into the TPS. The hoodscoop is in close proximity to the throttle body.
1993 Citroën XM Turbo C.T.
1993 Ford Spectron XL-T
1991 Fiat Croma 2.0T i.e.
Another car, soon to be announced
Mine always runs like hell for a several miles after washing. Never had that problem with the EA81.
LaureltheQueen
- Spelling Nazi
greg donovan
not even w/the distributor getting wet.evolutionmovement wrote:Mine always runs like hell for a several miles after washing. Never had that problem with the EA81.
my 85 ea82 was so bad at letting water into the dist. that i carried a spare cap and rotor in the glove box.
it actually died on railroad tracks once.
96 Impreza L sedan
97 legacy outback limited
00 Impreza RS sedan
00 Impreza RS sedan
Most of the cars I've had do this to some degree. I wouldn't use pressure washing at all, it'll distort rubber boots and shoot water into places you definitely don't want it.
A few minutes of spirited driving will usually fix it, unless its an old distrubutor car and you've loaded that up
tris91ricer
- Title Whore
rallysam
FWIW - I driven 90k miles in my Impreza RS with no hood scoop deflector - so the scoop is just wide open to rain - and never had any problems.
But, I have heard of this before, so I have only washed the engine compartment a couple times ever. No problems yet, but still trying to avoid more.
'00 Impr RS - sold
LaureltheQueen
- Spelling Nazi
LaureltheQueen
- Spelling Nazi
LaureltheQueen
- Spelling Nazi
That's why the horn is supposed to be mounted downwards to allow water to drainnzKAOSnz wrote:the biggest problem i encounterd was water getting into the Alarm horn and effectivly silencing it.
Lucky i got recipts. Its happenen twice. Next time the alarm horns going into the wheel arch.
93EJ22-Loosy
anyone ever use simple green...wait 5 minutes then hose off? follow it up with a nice coat of endust (some use WD-40 but it is sticky and collects dirt after awhile) and you are all set.
redesigning my '93 Leg Wag in my head...and then looking at my bank account...and crying.
Cant believe there are more of me out there!!!
Actually simple green is not good for aluminum if left on for too long
http://consumer.simplegreen.com/cons_faqs.php
93EJ22-Loosy
Although this is true, it is also stated on that site that if you do use it, keep it under 10 minutes and they follow that by saying "Unfinished, uncoated or unpainted aluminum cleaned with Simple Green products should receive some sort of protectant after cleaning to prevent oxidation." This is where the WD-40 and/or endust comes in. They are used to add a protective layer over the exposed aluminum and to aid in repelling water, air, etc.
I agree it is a risk, but if only done on occasion I feel the risk is negligible.
93EJ22-Loosy
