I have a friend (no, it's not me) who has an L with a stubborn overheating problem that no mechanic has been able to trouble shoot as of yet.
Here's what's been done so far:
He replaced the radiator with a new one.
He replaced the water pump.
He put in all new hoses.
He got a new radiator cap.
He replaced the thermostat.
Some symptoms and info
At one point he found metal in the oil and it turned out to be from the water pump apparently.
It does fine on idle, overheats on the highway.
It's odd that it overheats on the highway because I'd think that the air would keep it cool. Usually you'll get overheating when you stop. They've basically replaced his entire cooling system except the fan.
Who can figure this one out?
--Scott--
1991 - Rio Red SS
1991 - Rio Red SS
tris91ricer
- Title Whore
Metal in the oil? The water pump doesn't come in contact with the oil....?
Is it an OEM thermostat?
Has the system been properly bled of air?
If everything else is fine, I'd lean towards head gaskets.
Is it plausible that cooling passages (either in the water manifold or in the motor itself) are clogged? Has the system been power flushed or anything?
Did they check the coolant for exhaust gas? It could potentially be something like a leaking head gasket, right?
Is the water pump lubricated by motor oil? I thought its bearing was sealed.
Unless they do a test for hydrocarbons in the coolant and it comes back negative, I wouldn't rule out the head gaskets. Other possibility is a crack in the head or block.
I guess they pumped coolant through the system and tested for leaks.vrg3 wrote:Is it plausible that cooling passages (either in the water manifold or in the motor itself) are clogged? Has the system been power flushed or anything?
--Scott--
1991 - Rio Red SS
1991 - Rio Red SS
Hmm... If chunks of water pump got into the coolant, it does seem plausible that some could still be in the system somewhere... And if they block flow enough, couldn't that cause the water pump to cavitate at higher speeds?
