what mods to do and where to start?
superlowsub
I have just recently bought a 1991 GT legacy. I what to get some ideas on what mods to do in the turbo department, as this the 1st turbo sub I have owned.
Right now I am planning to instal a boost tap and raise the boost to around the 14-15psi level and may be remove the cats. I have replaced the factory air filter with a pod filter.
I guess I want to know best to go about this whole set up and if it is worth me replacing the factory BOV with a bigger one as the boost if up a bit?
any help you guys have would be great
tris91ricer
- Title Whore
scottzg wrote:The only thing you mentioned that isn't a bad idea is to remove the cats.
...And removing the cats makes mother earth hate you.
lies, my car runs cleaner without them
-jason
I assume your cats weren't in good condition then. It's impossible for a catless system to be cleaner than a catted system.
IronMonkeyL255
IronMonkeyL255
true. I was thinking EJ22T for some reason.
That means he already has an AWIC, doesn't it?
Rio Red '91 Legacy SS
tris91ricer
- Title Whore
superlowsub
I was wondering if i would have fuel cut issues when rasing the boost levels. I guess I will give it a shot and see what happens. If it does create an issue is there a way to get around the fuel cut out?
by the way I am in NZ and the the car is a jap-import thats why its got a GT badge. I am not quite sure but I think it is the same basic car as the RS legacy but a wagon with a lit bit smaller turbo set up.
Sounds good, do the exhaust, raise the boost a little.
Just so you know we got a very different Legacy turbo engine than the rest of the world. It's a 2.2L with a very small turbo and no intercooler.
Try looking around here: http://www.rslibertyclub.org/forums/
for more info about the jap/aus spec cars. Not that you're not welcome here.
02 WRX Sedan, 5mt
93 Sport Sedan, 5mt
93 Sport Sedan, 5mt
