What have you done to make a part "fit"???
dscoobydoo
Post by dscoobydoo »
Ok. I ordered this set of 19-21mm rear sways for the car. I get underneath and realize that the fit is just a bit off. So I call up and go WTF?? :evil:
If you have been underneath the rear of the car, you will see that the tire carrier has a small extension below it about the size of a 2x4.
WELL, it seems that to get the bar to fit, you have to "make" this extension disappear by beating it upwards into the tire carrier. :roll:
IT seems they ( the people I ordered this part from ) have done this numerous times without issues. :shock:
BUT I HAVE AN ISSUE WITH BEATING MY CAR TO MAKE SOMETHING FIT!
So I suck up the experience (because I can't return the item as it will fit, but I refuse to beat my car)
And I ordered the whiteline 20-24 adj rear sway for the car ( as I am 99% sure this will fit without issues) from someplace else.
SO, what have YOU done to make something fit???????
Yes I have too many Subarus
No you can't have one
05 GD-STI
01- RS- Swapped-07 STI
00- GF
scottzg
Post by scottzg »
I bet you got an impreza bar.
It doesn't fit if you have to beat on the car. I would raise hell.
Ask if a jaws-of-lifed roof makes a car a convertable, or if a b18c fits because you can close the hood on it.
THAWA
Post by THAWA »
yep, sounds like an impreza bar.
dscoobydoo
This is what kills me: The part sticker says: 96-99 Legacy but they had to do the "fitting" to make it work on those years too.
So yes, it is a generic bar designed for an Impreza and will "fit" a legacy with a few "alterations"
Hence my frustration
05 GD-STI
00- GF
Post by BAC5.2 »
I've cut the shit out of things to get them to work. I've "carefully" ground, cut, drilled, tapped, died, twisted, bent, and mangled most of my custom install jobs.
All part of the fun! :)
Kelly
Post by Kelly »
Meh, all part of "modifying" a car. Its just a car, not like its a baby or something. Shit, people even "modify" those.
scottzg
Post by scottzg »
rallitektech wrote:Meh, all part of "modifying" a car. Its just a car, not like its a baby or something. Shit, people even "modify" those.
I'm gonna get quad exhaust on my baby 8)
Post by entirelyturbo »
Strange.
I thought only the 90-91's had that little notch.
I bought what was supposed to be a 93 turbo rear sway from a board member, and it wouldn't fit, because my tire carrier as well has this notch which the 93 bar didn't have a kink to accommodate for.
So I actually got a 91 turbo rear bar which did have the kink in it, and it fits perfect.
So your car must be a weirdo because it has that notch in it :?
*Formerly DerFahrer*
tris91ricer
Title Whore
Post by tris91ricer »
quad exhuast toddler? Looks like Huggies/Pampers will be thinking up something new..
[b]'92 L Sedan[/b]
EJ20g 4.11 5sp LSD
[/quote]
dzx
Post by dzx »
Lots of swearing, occasionally a large hammer.
///M
'93 Legacy SS - part out
LaureltheQueen
Spelling Nazi
Spelling Nazi
Post by LaureltheQueen »
plasma cutter and a relatively large amount of brutal hammering for my bumper beam...
Laurel Tuning Stage 15
92 Touring Wagon 5MT 16G
Yukonart
Cradle Robber
Cradle Robber
Post by Yukonart »
LaureltheQueen wrote:plasma cutter and a relatively large amount of brutal hammering for my bumper beam...
Das roight.
1994 & 2005 Legacy GT Wagons
