Mod laundry lists
scottzg
Mod laundry lists
Post by scottzg »
It's nice here because nobody has a 20 mile long tag line of modifications, but they're kind of nice for seeing what people have done and whatnot. So i propose we stick up a list of car info here with all the things you've done.
So:
90 L sedan, awd 5sp 101k
2.5rs struts, springs
18mm air suspension rear swaybar
group n rear topmounts (ill do the front some day...)
snorkusuctomy -> cone filter -> boxed cone -> snorkusuctomy -> stock
custom center console/MP3stereo/speakers (cause my dash got torn up :evil: )
turbo front brakes
wagon prop valve
axxis ultimate pads (all 4)
wrx rims/turbo legacy rims
shimmed steering rack, swaybar mounts
redundant heavy guage wiring/ ground kit
anal retentive fluid maintenance
voltage guage
shortish throw shifter
CB with loudspeaker
extravisions with clear headlights
sachs HD clutch
Urethane steering rack bushings
short lists are ok!
Subaru_Nation555
Post by Subaru_Nation555 »
Engine/Exhaust:
K&N
HKS downpipe
custom 2.5" midpipe
Magnaflow muffler
Suspension:
KYB GR-2 struts
STi group N mounts
Whiteline adjustable rear swaybar
Whitline rear endlinks
Brakes:
Brembo OEM rotors
EBC Greenstuff front pads
Goodridge stainless lines
Appearence:
WRX wheels
Toyo Proxes 4 205/55-16
Hella 500 driving lights
De-chromed
Legacy vinal decal
Coming on tuesday:
WRX calipers/brackets
Racing Brake slotted rotors
Hawk HPS pads
ATE Super Blue fluid
Summer plans:
H&R springs
Boost gauge
Exhaust tip
Tune up
Liberty/Legacy AWIC
MBC
Walbro fuel pump
TD05-16G?
Last edited by Subaru_Nation555 on Thu May 12, 2005 1:38 am, edited 2 times in total.
'06 Impreza 2.5i wagon
skid542
Post by skid542 »
Engine :
Grounding wire modification
Wheels/Brakes :
Turbo rims with 205/50/15
Turbo Bradi slotted and cyrotreated rears
Mintex 1115 pads
Lights :
Polished headlights
Shifter operated brights switch
Misc. :
Removed the AC
Stereo upgrade
Lee
legacy92ej22t
Post by legacy92ej22t »
Mod list:
1992 White Legacy Sport Sedan 5mt
Removed snorkus, K&N filter
Saab 900 TMIC
Deadbolt's, Monster TD05H-16G turbo w/black Xtreme ceramic coating on the hot side and normal grey ceramic on the cold.
Boostjunkie engine swap.
Diamond coil pack.
VRG3 Engine Control, Phase II FCD.
Joe-P MBC set at 16 psi (9 psi till the clutch goes in).
Autometer Phantom Boost gauge 30-0-30 vac/boost.
Go Fast Bits light weight underdriven crank pulley.
STI Group N engine mounts.
STI Group N tranny mount.
CES Racing Systems 3" SS semi-race (catless) turbo-back exhaust with ceramic coated twin dump down pipe (DP03). CES, Boost Enhancement Plate (BEP). Supercat straight through 3" resonator and Supercat straight through 3" muffler w/ 3" straight tip.
Carsound 3" high flow cat (swap in for emmissions tests).
CES Racing Systems up-pipe and cross-pipe.
Rotors, Mountain in front & Bradi in rear.
Can't remember what my pads are.
Summer: OEM 16" WRX wheels with RE-92's (for now).
Winter: OEM 15" Legacy SS wheels with 4 studded Goodyear Ultra Grips.
Pilot steering wheel.
Momo aluminum shift knob (euro subaru edition).
Alpine 7830 CD.
Currently under the knife for(parts in hand): WRX hood scoop, Autometer Phantom series EGT, 3.9 rear LSD, STI Group N strut top mounts, GR2's w/ Tein springs. (soon in hand)Walboro 255, SPEC stage1 clutch and ACT streetlite FW. (project) Rebuilding original EJ22T.
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
scottzg
Post by scottzg »
matt- do you have sti mounts on original suspension? Or replaced stock suspension? What's that like?
LaureltheQueen
Spelling Nazi
Spelling Nazi
Post by LaureltheQueen »
*ed things will be in within the next 2.5 months
Bridgestone Potenza RE750 tires*
17" Sport Edition Fox 2's*
EBC Redstuff Brake Pads
Cryo-Treated front rotors*
KYB AGX Struts
Whiteline Control Springs
Cusco Rear Sway Bar*
Front Wheel Drive CV Axles
Wagon Prop Valve :P
JDM Air to Water Intercooler*
GM heater core acting as heat exchanger
Nalgene Bottle water resevoir*
Perrin Downpipe*
insert turbo here*
Samco Silicone Couplers*
Manual Boost Controller*
Vikash FCD*
STi Axleback
WRX Midpipe
Pioneer Premier DEH 940 Deck
Diamond Audio M3 6.5" front components
Free panasonic 6.5" rears
10" sub*
Custom 10" sub box*
2 amps for sub and speakers*
blue underbodies(yes i'm a ricer)*
20% Tint*
2002 WRX front seats
Hella Supertone horns*
Good Alarm w/ remote start
Last edited by LaureltheQueen on Wed May 11, 2005 7:14 pm, edited 2 times in total.
Laurel Tuning Stage 15
92 Touring Wagon 5MT 16G
jamal
Vendor
Vendor
Post by jamal »
LaureltheQueen wrote: blue underbodies(yes i'm a ricer)*
Oh no you didn't
Well, if things go well tomorrow, I'll have:
ver8 STi take-offs with Group N rear tops
18mm turbo rear sway bar
Intrax rear camber bolts
I also have WRX wheels with RE92s (which I've pretty much destroyed in 6 months), and Hella FF1000 driving lights.
Going in sometime this summer will be WRX front brakes (I've got the calipers and brackets) a wagon prop valve (anyone got one?), and new tires.
peter@functionauto.com
legacy92ej22t
scottzg wrote:matt- do you have sti mounts on original suspension? Or replaced stock suspension? What's that like?
Only the STI group N tranny and engine mounts are on the car so far and have nothing to do with the suspension. They're very nice though.
The STI strut top mounts (I assume these are the ones you're talking about) arent' in yet but will be going in with GR2's w/Tein springs.
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
Post by BAC5.2 »
OK, here we go....
1994 Legacy Sport Sedan, Aegean Blue Metallic.
No Snorkus
K&N filter
Coffee Mug
MBC
SAAB 900 TMIC (10 row)
HKS Super Sequential BOV
TDO5H-16G, ported polished and coated.
CES Racing Systems 3" SS race (catless) turbo-back exhaust with ceramic coated twin dump down pipe (DP03). CES, Boost Enhancement Plate (BEP). Supercat straight through 3" resonator and Supercat straight through 3" muffler w/ 4" rolled chrome tip.
STi Group N engine/tranny mount
Exedy Stage1 clutch (WRX Sized)
Exedy LW Flywheel (WRX Sized)
Custom Short Shifter
Custom Shifter Bushings
Redline 75W90NS tranny and diff fluid
Racing Brake front rotors (WRX Sized)
Hawk HPS pads
BRADI Rear rotors
SBS GS6 pads
SS brake lines
ATE Superblue fluid
Relocated battery to trunk
Custom WRX coolant tank
Autometer Phanton Boost gauge
Pioneer headunit (the DEH-860 I believe)
99 Impreza RS Interior
MOMO Shift Boot
OEM WRX Shift knob (winter)
Greddy TRUST shift knob (summer)
Custom fiberglass dual-din-delete plate
HKS Type0 Turbo Timer
VRG3 FCDII
Sylvania XTravision lights
35% tint all the way around
WRX wheels with RE92's (winter)
Rota SubZeros w/ 225/45/17 Bridgestone RE070's
On the table (This summer):
3.9LSD, coilovers (whenever that issue gets settled), Noltec Camber/Castor plates, WRX Intercooler with Greddy Type S BOV, WRX Hoodscoop, SS Clutch line, Single Stage Brake Booster, Energy bushings for everything, Whiteline sway bars (eventually).
I probably left out a lot of stuff, but that's what I could think of right now...
Wow, it's hard to remember every little thing... It was more fun to try than I expected, though:
93 turbo sedan, 5MT, somewhere around 125,000 miles
Draw-tite trailer hitch
KYB GR2 struts
Worn-out stock springs aided by rubber spring spacers in the rear
WRX wheels, Krylon'd black
Hankook Zovac H404 snow tires
Hella FF75 driving lights
WRX front brakes with Axxis Ultimate pads
Axxis Metal Master rear pads
Cryo-treated brake discs
Goodridge stainless steel brake lines
Single stage brake booster
Wagon proportioning valve
Heavy-duty headlighting harness
R-134a retrofit
Autometer boost gauge
SunPro water temperature gauge
SunPro voltmeter
Cobra CB radio
Rockford Fosgate MP3 head unit
Stainless steel clutch line with deleted damper
Speed bleeders everywhere (calipers, ABS pump, clutch slave cylinder)
Custom intake resonator delete
Auxiliary purge system delete
40-cent boost controller (utility spring in parallel with wastegate actuator)
Saab 900 intercooler
1st-generation DSM blowoff valve
2nd-generation Legacy wagon windshield washer tank (holds 1 gallon)
Intercooler spray
Slightly bent driver side wiper arm to press harder against windshield
Coolant filler tank delete
Magnecor ignition leads
MSD DIS-2
Diamond ignition coil pack
Diamond ignitor, relocated to passenger side strut tower
4-wire oxygen sensor off a lightly used and then destroyed Korean car
Remote starter with keyless entry
No-name eBay downpipe
CES uppipe
High-output bulbs (9003XV, 2357NA, W5W, 3496, 3497)
Blinking sidemarkers
Clutch safety switch bypass
Redline MT-90 manual transmission fluid
WRX oil/water heat exchanger
Dash-mounted test mode and read memory mode switches
Leather shift boot
J-MoNeY
Post by J-MoNeY »
De-snorked
K&N Panel
Mugged
Joe-P MBC
WRX IC
Custom Hardpipe
Diamond Coil Pack
FCD
DC2-TT
HD Clutch
Perrin Pully
No AC
WRX Coolant Tank
WRX Wheels
RE-92's
Smoked Side Markers
De-Chromed
Repainted
JDM-Fogs
Walbro 255
Massive Skidplate
Now working reverse lights
94 CD Player
27% Tint
Forge BOV
98 LGT
tris91ricer
Title Whore
Post by tris91ricer »
27% that's a pretty odd percentage! Where'd you get that?
[b]'92 L Sedan[/b]
EJ20g 4.11 5sp LSD
[/quote]
douglas vincent
Post by douglas vincent »
1990 Legacy Wagon
Metal master rear pads
? front pads
16" WRX rims and RE-92s
KGB struts front
? rear struts but new, can't remember name
Gutted interior
Engine
2.2 NA block
Rock Pistons
Jap Rings
Shot clutch
Walbro Fuel pump
370 CC Nismo injectors
Bosch (MSD branded) 1-1 rrfpr
Eaton M62 supercharger
7.25 Oversized crank pulley
Oversized alternator pulley
AWIC with pump and radiator, still need a resevoir
Occasional nitrous setup
Stock short shifter, (remove stock handle=presto, short shifter)
Custom intake for Supercharger.
Tleg93
Post by Tleg93 »
Edit
Saab 15 row fmic
Autometer z-series boost gauge.
3" WRX dp
HKS "style" flex uppipe
soon to be installed.
--Scott--
1991 - Rio Red SS
J-MoNeY
Post by J-MoNeY »
91legacy_sleeper wrote:27% that's a pretty odd percentage! Where'd you get that?
Colorado. That's our "legal" limit for tint. Stupid jerks here. :x
98 LGT
Yukonart
Cradle Robber
Cradle Robber
Post by Yukonart »
Don't feel bad. . . it's 35% in WA.
1994 & 2005 Legacy GT Wagons
J-MoNeY
Post by J-MoNeY »
:-O
98 LGT
azn2nr
Post by azn2nr »
tdo5h 16g
fmic with coated pipes
3 inch tbe bellmouth
trubosmart 2 stage mbc
custom intake, every last bit of it
pnp throtle body
autometer autolite boost gauge
panosonic deck
agx whiteline combo suspension
-jason
Since when does it matter wheter it's legal or not ;)
I've got 20% on mine all the way around, and technically it hasn't been legal in all the states I've lived in.
free5ty1e
Post by free5ty1e »
Wish I had tint... anyways:
1994 Legacy Sport Sedan, ~227,000 km (Canadian version / no automatic deathbelts) / 5MT / white: Purchased for $3800 almost 3 years ago.
Removed snorkus / enlarged fender airbox entry hole to 3" / added 3" PVC 90 degree elbow in fender to direct air in from foglight hole / removed foglight blocker
Target Coffee cup mod (Unspillable!)
Rebuilt / hybrid stock turbo with T-bird compressor wheel & housing (not that much of a difference IMHO)
TurboXS bleed MBC (to be replaced with a $10 ball-and-spring hardware store MBC, already built) running at 9psi due to a worn clutch (usually 15psi)
WRX black hoodscoop (to feed my old Saab 900 TMIC, or should I say, interheater) - now just directly cools the turbo / chimney / engine compartment
Izuzu FMIC from eBay, all kinds of custom work to mount and route. Bumper's cut, headlights are spaced out bug-eye style. Now with piping that doesn't blow apart! :)
Dremeled turbine exit and exhaust entrance for minimized backpressure
3" custom mandrel-bent downpipe, 3" custom press-bent exhaust all the way back to 2.5" dual exit muffler that came with the car (has been flared / enlarged to seat the 3" exhaust)
Eventually, the Hooker 3" glasspak I have sitting in my truck will replace the stock muffler.
Coolant tank relocation to old washer bottle location. Washer bottle removal, replaced with Ford washer bag behind passenger headlight, hung with zipties.
Diamond coil pack
Updated / white wire knock sensor
Autometer Phantom boost/vac gauge, narrowband a/f ratio, and 0-1600* F EGT gauge with type K thermocouple drilled and clamped into preturbo header piping
Surplus (Skycraft) marine voltmeter ($5)
Autometer Phantom fuel pressure gauge with failed pressure transdeucer, older model so must buy new one...
Rocky Mountain Radar RMR-C430 radar/laser detector/jammer
Pocket PC with vent mount and GPS kit
Home-built dual 12" sub box, with completely separated 7' plywood labrynith bass ports. Rockford Fosgate Punch subs. Rockford Fosgate oldschool 4-channel amp (brought back from the dead and repaired), bridged (two channels per sub)
Sub box has been hung and wedged into place in the trunk, in such a way that the built-in Subaru toolbox and spare tire is still completely accessable without having to move the box.
Electro-luminescent lighting strips on underside of dash (this was for testing of a prototype EL controller my father and I built, and its still in and working. Can glow white, green, blue, purple, or undulate between the colors in time to the stereo's bass output)
MP3/CD player, not installed yet
ACT organic WRX clutch kit with HD pressure plate (not in yet)
ACT streetlite 13.9 lb WRX flywheel (not in yet)
Oh yeah, the VRG3 FCD! How could I forget?
Oh and the remote starter with master door lock motor (for driverside door lock - and remote unlocking / locking / arming of alarm / starting of car / turning car off)
APEXi Turbo Timer, usually set to a default of 1:30 for cooldown
VRG3's scan tool parallel connection and laptop power wired in under passenger seat / dash
Man... this is tough to remember everything. I think I got it all but hey - probably not :) Interesting thread!
Edit: Forgot about the PCV rerouting with a breather on the end, no more oil in intake path - it all drips down a frame rail and eventually to the ground now, if anything.
Edit 2: Damn I'm forgetful. Had a GReddy Type S BOV, leaked at idle and was a bitch to adjust, also heard bad things about it holding decent boost levels - replaced with an HKS SSQV, guaranteed not to leak at idle or ANY boost pressure up to almost 50 psi. Sounds pretty cool, loud as a mofuggah. Gets too much attention right now, though, when my clutch is slipping and my boost is lowered. But at least it works, and works properly.
-Chris
91SS 4EAT stock, 200k mi
LegacyPunk
Post by LegacyPunk »
93 sports sedan
2.5 inch cat back exhaust
Turbo XS MBC
K&N drop in
Big ol 02' WRX STI hood scoop (for the WRX intercooler that used to be in/ might be back in this summer)
autometer boost guage and Air Fuel
KYB GR2's
Brembo OEM Rotors
Falken Ziex 502 (or 512 can't remember)
Removed AC/ moved coolant tank to AC area
I miss buying new parts for my car, and by new parts I mean not replacement parts :lol: .
:twisted::cool::twisted: "Plenty of time, to ruin my life, so why start now?" The Movie Life
1993 Sports Sedan, Exhaust, MBC, 02 WRX IC, KYB GR-2s...Now with old back seat!
93Leg-c
Post by 93Leg-c »
Just FYI, I don't believe 27% film is made. CO's law is "net" meaning that the combination of the window film plus the existing tint in the glass cannot have a visible light transmission of less than 27%. So, tinters use a 30% film, and factory tinted glass lowers it another 2 to 3% so it comes out to 27%.
Whereas Art is in WA and their law is 35% "film" meaning that you cannot (should not) use a film that is less than a 35% film whether or not the factory glass is absolutely clear or comes with a tint.
BTW, in CO there are two sets of laws. If you want your front driver's and passenger's windows tinted, then the darkest you can go is 27% all the way around, legally. But if you want it really dark in the back, you can go as dark as you want (like double or triple limo tint) PROVIDED that the driver's and front passenger's window have NO TINT on them.
Sorry, didn't mean to be so long nor to hijack the thread.
'94 TW
Kelly
Post by Kelly »
91 turbo leg
red paint
half eaten bag of sunflour seeds
full ashtray
grey carpet, kinda
oily motor
redline in the blinkers
werd
Post by entirelyturbo »
Yeah, mine's gonna be the shortest :(
91 Legacy L 4WD
Turbo rear swaybar
Turbo shifter knob and boot
JDM wagon floormats (y0!) :lol:
Throttle body bypass
Old-ass JVC head unit
*Formerly DerFahrer*
douglas vincent
No, my wifes is shortest
1990 sedan
stock
