What size is a wrx front swaybar?
THAWA
Post by THAWA »
I've read everywhere from 17mm to 21mm but no definative answer. Does anyone know for sure?
Yukonart
Cradle Robber
Cradle Robber
Post by Yukonart »
Well, Whiteline upgrades are 22mm, so I'd say it's probably not quite 21mm stock. I'm going to wager a guess at around 19mm.
(I'm still searching for you, though.) ;)
1994 & 2005 Legacy GT Wagons
Yukonart
Cradle Robber
Cradle Robber
Post by Yukonart »
Okay. . . hmmm. I'm finding out that the WRX sedan's REAR sway is 20mm. That's interesting. I would think the stock front one would then be larger. . . perhaps it IS 21mm. :?
scottzg
Post by scottzg »
Yukonart wrote:Okay. . . hmmm. I'm finding out that the WRX sedan's REAR sway is 20mm. That's interesting. I would think the stock front one would then be larger. . . perhaps it IS 21mm. :?
Wrx suspension stuff doesnt translate to logic that well because of the widened front track messes up all our tuning logic. Thus the wagon has the 17mm rear and no flares.
it's 19 iirc.
It doesn't fit our cars and we can't use them as a guidline for tuning.
Yukonart
Cradle Robber
Cradle Robber
Post by Yukonart »
Indeed, Scott. Just beat me to it. Subydude has the specs on a page comparing the Perrin swaybar to them.
http://www.subydude.com/parts/details.php?7171242
This is kind of what I though about the sedan stuff, anyway.
Whoah. . . so a WRX wagon swaybar should fit a BC/BF?
N/M Just searched, and that spare tirewell is going to be the problem on Laurel's car. Looks like that Cusco car we were offered will have to go back. :(
jamal
Vendor
Vendor
Post by jamal »
There have been 17 and 20 mm rear WRX sedan swaybars. I think 02-03 is 17, and they went up to 20 for 04-05, or something like that.
peter@functionauto.com
scottzg
Post by scottzg »
other way around.
SOA recognizes that WRX owners cant drive. :lol:
THAWA
Post by THAWA »
So the front doesn't fit? Why not?
Yukonart
Cradle Robber
Cradle Robber
Post by Yukonart »
THAWA wrote:So the front doesn't fit? Why not?
I think the track is too wide. . .making for a swaybar that's also too wide.
Sounds like the wagon sway might work, though.
THAWA
Post by THAWA »
Well AWD NA's have a shorter track than turbos and FWD's but the swaybars are interchangeable. Has anyone actually tried using it to confirm?
Pretty sure the sedan bar won't fit with the wagon one is that the mount points are on the A-arms, which are different between sedan & wagon.
So assuming the bends are the same, a wrx wagon front bar should work.
