Tire Pressures
Subaru_Nation555
Tire Pressures
I have WRX wheels with stock size tires (205/55-16). Just wondering what pressures other people with the same tires are running? Mine are at about 36F/33R
'06 Impreza 2.5i wagon
Depends on the tire, but I'm running 40/40 with the Kumhos.
rallysam
FYI - That size tells me these are RS wheels - not WRX. right?
The specs for an RS:
32 front, 29 rear
You've got 12% more weight, so I think you're right on the money already.
32 front, 29 rear
'00 Impr RS - sold
