Now the car won't start unless I do the same thing (one key in the 12V trailer hookup and one in the ignition). The wire that the trailer hookup is tapped into (goes to the ignition) has power. The switch works in the accessory position, but won't start the car.
Do I need a new ignition switch? Is there points inside it that could be burnt out?
