I don't think it would be so bad if they projected it onto the part of the windshield where it is just blocking your own hood. I don't know why they project it way up on the glass where you are trying to see where you are going!BAC5.2 wrote:I hate heads up displays. I drove a C6 Vette and some other shitty GM with it, and on the track it just gets in the way.
They draw your attention to the bottom of the winshield, when you should be looking ahead and through the turns.
That's the problem. It's either right in the way of where you need to be looking, or it's to low and draws your attention directly in front of the car instead of looking ahead.rallysam wrote: I don't think it would be so bad if they projected it onto the part of the windshield where it is just blocking your own hood. I don't know why they project it way up on the glass where you are trying to see where you are going!
That's the "Pipper." The computer predicts a few seconds into the future based on a bunch of stuff and where the rounds would fall. But that's 70's tech. The new stuff (that we know about) has a helmet mounted HUD that can tell where a pilot is looking and fire without adjusting the attitude of the aircraft.-K- wrote: The cool thing on aircraft is it will give you a gyro adjusted aiming point for your guns.
