why is my coil pack different ???
dumbskate
Post by dumbskate »
when i went to look at what condition the spark plug wire on my newly purchased '90 legacy project were like i noticed that there weren't any.
instead i found as im sure you all know, there was one coil on each spark plug mount.
can someone tell me why they did this and is it better to upgrade to a more modern "coil pack" with 8mm cable or is this somewhat odd approach going to work just fine ?
thanx
Warp3
Post by Warp3 »
Considering many newer cars (like the USDM WRXs) use the coil on plug method, I'd think that it is a better design than the coil/plug wire setup. At the very least, you don't have to worry about plug wires that wear out every few years.
Shane
2006 Subaru WRX TR
1989 Toyota MR2
dumbskate
Post by dumbskate »
thats a good point id assume that with the coil set up like mine there is less wasted current because the distanse between coil and plug is so small.
good to know
anyone else with an opinion
Where are you? Either you're not in the US (did the overseas cars have coil on plug back then?) or that's a transplanted engine.
azn2nr
Post by azn2nr »
im betting motor swap. even my moms 97L has a coil pack
-jason
dumbskate
Post by dumbskate »
im in new zealand actually and yes the car did have a motor swap but it should just been swapped for another 91 ej20 engine.
i really want to get to the bottom of this one.
can someone tell me why they changed to this system in the later models like the wrx mentioned above ???
very interesting
azn2nr
Post by azn2nr »
i dont know why they did it only that they did, if you could take a pic of the motor it would help detrmine what motor or at least around what year the motor came from. things like intercooler, coolant fill tank, intake manifold and coolant lines for the turbo will help identification
-jason
dumbskate
Post by dumbskate »
well first off it's N/A so maybe that it part of the confusion everything on it looks early nineties exept for the coil set up
