Recommended Oil for rear Diff?
Posted: Fri Dec 13, 2002 7:20 am
by eastbaysubaru
Just curious what everyone is using? I'm pretty sure I'll be using some synthetic when I change it next, but I'm not sure which one to use. What's everyone here using?
-Brian
Posted: Fri Dec 13, 2002 7:25 pm
by entirelyturbo
I use Valvoline 80W90 SynBlend gear oil in my diff and manual tranny. The only problem I had changing mine was how stiff the plugs can get!
Posted: Fri Dec 13, 2002 7:55 pm
by rlima
Red Line 75W90 Gear Oil.
This is specially formulated for LSD if you have one.
Roy
Posted: Fri Dec 13, 2002 8:19 pm
by eastbaysubaru
Nope, no LSD here AFAIK. Good info guys. Anyone else?
-Brian
Posted: Fri Dec 13, 2002 11:54 pm
by ciper
Easily available, Mobil 1 full synth 75w-90 for front and rear diff.
subyluvr2212: No kidding they can get stuck. I wasnt able to change it on the rear of my BC legacy (bf was fine). I used the correct size and bent the INSIDE of the plug
Posted: Sat Dec 14, 2002 11:58 pm
by JasonGrahn
Posted: Wed Jul 09, 2003 6:52 am
by eastbaysubaru
How much fluid in the front and rear diff? I know the answer is probably in the book, but I'm lazy and it'd be helpful to have it in this thread
-Brian
Posted: Wed Jul 09, 2003 2:03 pm
You're right it's in the book.....owner's manual to be more percise.
Posted: Wed Jul 09, 2003 4:09 pm
by eastbaysubaru
LOL!
-Brian
Posted: Wed Jul 09, 2003 7:41 pm
by Fernely
I am using redline shockproof, I belive if you get 2 quarts it will be enought to do both diffs. I think the rear is .7 quart and the front 1.3 quarts.
Posted: Wed Jul 09, 2003 8:07 pm
by ciper
Just realized someone recomended LSD dedicated lubricant. YOU DONT WANT TO USE IT!! The LSD is a sealed unit, friction modifiers arent needed. All you are doing is creating more drag in the differential.
