Recommended Oil for rear Diff?
eastbaysubaru
Post by eastbaysubaru »
Just curious what everyone is using? I'm pretty sure I'll be using some synthetic when I change it next, but I'm not sure which one to use. What's everyone here using?
-Brian
'04 PSM FXT
Post by entirelyturbo »
I use Valvoline 80W90 SynBlend gear oil in my diff and manual tranny. The only problem I had changing mine was how stiff the plugs can get!
1993 Citroën XM Turbo C.T.
1993 Ford Spectron XL-T
1991 Fiat Croma 2.0T i.e.
rlima
Post by rlima »
Red Line 75W90 Gear Oil.
This is specially formulated for LSD if you have one.
Roy
1991 Legacy Turbo AWD Sedan (5sp M)
Real roads don't have centre lines!
eastbaysubaru
Nope, no LSD here AFAIK. Good info guys. Anyone else?
-Brian
'04 PSM FXT
ciper
Post by ciper »
Easily available, Mobil 1 full synth 75w-90 for front and rear diff.
subyluvr2212: No kidding they can get stuck. I wasnt able to change it on the rear of my BC legacy (bf was fine). I used the correct size and bent the INSIDE of the plug :o
JasonGrahn
Post by JasonGrahn »
-Jason Grahn
eastbaysubaru
How much fluid in the front and rear diff? I know the answer is probably in the book, but I'm lazy and it'd be helpful to have it in this thread :D :oops: .
-Brian
'04 PSM FXT
You're right it's in the book.....owner's manual to be more percise. ;)
eastbaysubaru
LOL!
-Brian
'04 PSM FXT
Fernely
Post by Fernely »
I am using redline shockproof, I belive if you get 2 quarts it will be enought to do both diffs. I think the rear is .7 quart and the front 1.3 quarts.
We have two seasons in Miami, Hot and Hotter!
ciper
Post by ciper »
Just realized someone recomended LSD dedicated lubricant. YOU DONT WANT TO USE IT!! The LSD is a sealed unit, friction modifiers arent needed. All you are doing is creating more drag in the differential.
