zapjackson
Post
by zapjackson »
Where is my pcv valve. I am trying to use the sea foam engine restorer and it says to put it there or a vaccum line. Can someone help me.
Mod edit: It's a PCV valve (Positive Crankcase Ventilation valve) not a PVC (PolyVinyl Chloride valve)
legacy92ej22t
Post
by legacy92ej22t »
It's on the side of your throttle body, on the passenger side. I'll try and get you a picture.
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
legacy92ej22t
Post
by legacy92ej22t »
OK, in this pic it's the black line coming into the left side of the TB. It's in the middle of the picture, just off center to the left at the bottom.
See it?
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
THAWA
Post
by THAWA »
It's the rusty thing at the bottom
legacy92ej22t
Post
by legacy92ej22t »
Hey now, don't be dissin' my rust.
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
THAWA
Post
by THAWA »
your rust is HOTTT!
petridish38
Post
by petridish38 »
To run Seafoam, I usually use that black vacuum line coming right off the top of the throttle body... Its nice and centrally located.
Andrew
209,000 miles!
2002 Impreza WRX Sport Wagon
Tleg93
Post
by Tleg93 »
That's a good idea. It seems a lot easier too.
--Scott--
1991 - Rio Red SS
