second O2 sensor??????
andys2
Post by andys2 »
I have a JDM ej20G out of some sort of Legacy. This is the engine with a black AWIC. Anyway, I'm in the process of puitting it into my impreza and I can't figure out about this second O2 sensor.
One of the 02 sensors is a three wire unit - this is the one I have connected. The other is a 2 wire unit - and I have no idea where it connects to. I have been using the wiring schematics from a 92 Liberty RS and a 94 WRX - neither of which have two O2 sensors. \
Concidently I also have two unknown wires on the ECU (a16 & d9). I don't think these are for the O2 sensor as the wiring doesn't match. Any ideas?
BTW I have been very careful with the wiring and am pretty comfortable with the info from the doccumentation. So far the major difference between the Liberty-RS and the WRX info is the way the fans and AC control are organized. Neither of which I care about very much.
Finally, I also don't have much info on how the whole select reading / read data / read memory interface works. Anyone have any info onm this?
thanks,
-Andy
what year did the JDM engine come out of?
andys2
Post by andys2 »
I have no idea of the model year. Does it make that much of a difference?
gnuman
Post by gnuman »
andys2 wrote:I have no idea of the model year. Does it make that much of a difference?
Yes, as the model years you mentioned only use one O2 sensor for fuel trim. the second one (which really should be a 4 wire unit) is to monitor the efficiency of the cat (to get a finer tuning of the fuel mix, and to determine if the cat dies). If the engine is from a recent model year (post 1996 I think), then it will have the second cat on it, otherwise not.
1992 Legacy L Wagon 'Emily" Ice Blue, plush seats, roof rack, towing hitch, upgraded radio/CD player, LS alloy wheels, and lots of love! 180K miles and going very strong!
You will get my Legacy from me when you pry my cold dead fingers from the wheel.
andys2
Post by andys2 »
yes, but the first O2 sensor goes to the ECU - the second O2 sensor, the two wire one, doesn't go to the ecu. It goes somewhere else. Where could it have gone?
uh oh - looks like some road blocks :(
gnuman
Post by gnuman »
It should go to the ECU. . .
