Crank Bearing with Sealant??
Grounded1
Post by Grounded1 »
I am in the process of rebuilding an EJ22. I noticed during diassembly that the case halves at the bearing caps (I know this engine does not have bearing caps so pardon the term - it is the contact area when you bolt them down) had evidence of the same sealant that is used on the block case halves. Is this normal for a Subaru engine. The engines I've done before required nothing to be put there. In fact it is a critical area and improper torquing of the bearing cap could cause a crank bearing to spin. Has anyone seen this. If it's what Subaru calls for then no problem but as I said, I have never heard of this procedure before. Anyone familiar with this? :roll:
This engine was original out of a 92 Legacy.
Pat
91 2.2 Legacy Wagon
hackish
Post by hackish »
I don't think it's standard and I've never seen this on a subie engine. I would have to say that it would cause some clearance issues. Maybe someone in the past doing a rebuild though they'd be smart to keep the bearings in place when bolting it all back together. Personally I use lithium grease if things like this need some "gluing" as it dissolves in oil once the engine is started.
-Michael
