High Idle problems
THAWA
High Idle problems
Post by THAWA »
Okay, I've got the new engine in, it's pretty much good, but it's idling pretty high, like 2,000 rpms or so. I fiddled with the original throttle body's stop screws and that made no difference. I replaced that with a throttle body whose screws were still factory. Still, no difference. I replaced the coolant temperature sensor as the first one was broken, no difference. I plugged the IAC valve lines, the car start, then die immediately. I unplugged the iac valve, the car runs and idles at around 1,500 rpms up to about 2,000 rpms at times. What could be the problem? Intake leak somewhere? I've reset the ECU so many times that I don't know what to do.
J-MoNeY
Post by J-MoNeY »
Did you check the nuts for the cruse control and the throttle cable where they connect to the TB? When I put my newer engine in they were to tight causing the engine to idle high.
98 LGT
Post by entirelyturbo »
Like I said, I think it's IAC related. I think it's stuck open all the way.
*Formerly DerFahrer*
Does your TB have an air bypass screw on the top of it, like this?
http://www.main.experiencetherave.com:8 ... images/tb/
THAWA
Post by THAWA »
The old one did, it was one of the screws I adjusted. The old one had the throttle completely closed. The new one I haven't touched, it was idling fine on the old engine. I'm going to go try cleaning and adjusting the iac valve, if that fixes it I'll swap to a known good and calibrated iac valve.
JasonGrahn
Post by JasonGrahn »
It's gotta be IAC related. When i put the 2.5 in my car, i had to get an adapter plate made to put my original IAC on the car, nothing else would work correctly.
-Jason Grahn
THAWA
Post by THAWA »
when you remove the electronic protion of the IAC valve held on by two screws, should you be able to move the shaft inside with your hand?
dzx
Post by dzx »
What you described is the same exact thing my engine is doing. I switched the electronic part of the IAC today and it did nothing.
///M
'93 Legacy SS - part out
THAWA
Post by THAWA »
I can believe that if the mechanical part is stuck open.
J-MoNeY
Post by J-MoNeY »
J-MoNeY wrote:Did you check the nuts for the cruse control and the throttle cable where they connect to the TB? When I put my newer engine in they were to tight causing the engine to idle high.
TTT.
98 LGT
THAWA
Post by THAWA »
oh sorry, the throttle was never the problem, I had the throttle completely shut and it was still idling like this.
THAWA wrote:when you remove the electronic protion of the IAC valve held on by two screws, should you be able to move the shaft inside with your hand?
Yes, you should be able to rotate the valve back and forth with your hand. Have someone start the car, and you turn the valve with your hand. Or just turn it all the way in one direction, then try to start the car. One way, idle will be really high, other way, car may not start or idle will be really low.
Just out of curiosity. Have you checked the IAC valve's duty % via Vikash's scan tool?
THAWA
Post by THAWA »
Nope, but it doesn't matter. The mechanical part is frozen open. :) Guess I know what I'm doing today. I did however test the valve using the FSM's instructions. The electrical part tested fine.
Told ya ;)
THAWA
Post by THAWA »
Yeah yeah :) I just didn't want to replace something I didn't have to.
JasonGrahn
IN SUMMARY:
throttle closed, revving high, check ability of IAC.
-Jason Grahn
THAWA
Post by THAWA »
Well you should check both the mechaical part, and the electrical part.
JasonGrahn
agreed and edited. :)
-Jason Grahn
Matt Monson
Post by Matt Monson »
There seems to be a run of IAC failures, I sold all four of the spares I had in my inventory in the last 30 days!!! :(
2000 2.5RS daily driver.
1999 2.5RS w/ 50+ extra whp
Suby Hai!
Post by BAC5.2 »
I still have a BRAND NEW IAC valve...
THAWA
Post by THAWA »
I'm still not paying $200 bucks for one ;).
Swapped valves, works fine now. The old one is like really bad. I took a screw driver and tried to pry it by the door, and it chipped part of it off!
THAWA wrote:I'm still not paying $200 bucks for one ;).
You wish... I paid $362 list new for mine :cry:
dzx
Post by dzx »
Poor phil, stuck with money you cant spend. Kinda like my 400 dollar subwoofer that holds my keys in my room.
///M
dzx
Post by dzx »
I replaced the IAC and it seems to have solved most of the problem. Most of the time it idles normal now but sometimes it still idle's high.
///M
