Lots of 90-94 Legacy parts, Turbo and N/A
Blackbart
Vendor
Vendor
Post by Blackbart »
I have alot of parts for the 90-94 Legacys; interior trim, sensors, seats, doors, Diamond coil packs, TCU's, ECU's, heater coil, alts, suspension parts, dash board, A/C parts...........
Everthing but what you need, of course. :lol:
No power antennas, no turbo badges, no turbo wheels,
Are the black triangle things where the window goes up split at the very top?
Blackbart
Vendor
Vendor
Post by Blackbart »
Do you mean the plastic triangles that cover the mirror mounting screws? If that is what you need, I gottem. What color?
206er
Post by 206er »
got any turbo crossmembers? will probably be expensive to ship, but pm me a price.
Blackbart
Vendor
Vendor
Post by Blackbart »
Got rear crossmembers, fronts are gone.
Blackbart wrote:Do you mean the plastic triangles that cover the mirror mounting screws? If that is what you need, I gottem. What color?
Yeah. they all should be black. Is the top ripped? That's my main concern. I'll try and take a pic of what I'm talking about.
HomeSlice
Post by HomeSlice »
josh there called gussets
MY93BC Legacy Sonora Sand---> black plasti-dip?
MY93GC Impreza Amethyst--> Glacier/aspen/pd White
93BC"edm" 93GC 90BC R.I.P.
v8killer2pt5
Hood
Post by v8killer2pt5 »
Do you have a hood to fit a 94 Legacy, and the rear trunk dampners?
Damm this does not feel like my Sti!
Blackbart
Vendor
Vendor
Re: Hood
Post by Blackbart »
v8killer2pt5 wrote:Do you have a hood to fit a 94 Legacy, and the rear trunk dampners?
I got the hood from the turbo with the scoop, trying to sell it as a facelift set with the bumper, grill, fenders, etc.
Rear trunk dampners? Do you need the spring setup for the sedan or the shock type for the wagon? Have both.
gt2.5turbo
Post by gt2.5turbo »
how much for the coil pack including shipping? 80919
93 White Legacy Turbo Wagon: For Sale-ish
93 White Turbo Sedan: soon with a little more umf
91, funky brown purple gray color, legacy L Wagon: the "its so cheap i cant not pass it up" purchase to get me around when the others are down
rallysam
Post by rallysam »
How much for a turbo ECU plus shipping? (21230)
'00 Impr RS - sold
Blackbart
Vendor
Vendor
Post by Blackbart »
I have three diamond coil packs, $25 each delivered.
I have one ECU (sniff, sniff), best offer over $150. I don't realy want to sell it.
Blackbart
Vendor
Vendor
Post by Blackbart »
Josh,
I looked at the door, now I know what you want. The soft rubber between the mirror and the sail shaped plastic that covers the mirror mounting screws. Correct? Send me your adress and it's yours.
You were the first guy to help me out on the USMB with the code reading. Now it's payback time. Anything else you need, Josh?
rallysam
Post by rallysam »
Blackbart wrote:I have one ECU (sniff, sniff), best offer over $150. I don't realy want to sell it.
Ok, well I'm not sure I need it yet, so I will hold off for now.
'00 Impr RS - sold
roadhouse
Post by roadhouse »
pm sent for the tranny computer, rear wing and front hood with scoop. need more will send you another list
Josh,
Yeah the gussets. Here's a pic. However it doesn't show the rip at the top
http://www.main.experiencetherave.com:8 ... P_4254.JPG
If you have both left & right without tears at the top, I'd like both. Also could you send one of the screws that holds on the mirro. Some how one got lost on my passenger side.
That's about all I can think of. Thanks!
snowboarded
Post by snowboarded »
What suspension parts do you have?
And do you have aftermarket tranny or engine mounts?
[quote="Manarius "]Only flamers will get those. [/quote]
[quote="All_talk "]How many WHP will that give me? :)[/quote]
2010 Subaru Impreza 5mt 5 door
Blackbart
Vendor
Vendor
Post by Blackbart »
snowboarded wrote:What suspension parts do you have?
I have all the stock 92 turbo sedan suspension parts.
No aftermarket mounts.
snowboarded
Do you have a rear LSD?
Blackbart
Vendor
Vendor
Post by Blackbart »
snowboarded wrote:Do you have a rear LSD?
Nope
Blackbart
Vendor
Vendor
Post by Blackbart »
gt2.5turbo wrote:how much for the coil pack including shipping? 80919
Stock coil pack $15 delivered
Diamond pack $25 delivered
morgie
Post by morgie »
Do you still have the clutch/brake pedals assy and the clutch master cylinder (Hydraulic) ?
thanks !
morgie
'98 4Runner V6 Manual 4x4.
Blackbart
Vendor
Vendor
Post by Blackbart »
I just have 4EAT stuff, so far.
92BlackBeauty
Post by 92BlackBeauty »
PM sent about the facelift.
92 SS--up and running finally!!
(edited for Jason Grahns pleasure)
scuvdu
Post by scuvdu »
Do you have a pressure sensor and pressure exchange solenoid by chance? :?:
