knock sensor?
knock sensor?
when i started the car it right away was running almost as if it were missing on a cylinder, it was shaking the whole car but then it just quit and was running smooth and about a minute later it was running really rough again and it kept doing this smooth, rough, smooth thing any help?
91 Legacy Wagon, AWD
irishsetter
clean the MAF sensor
The MAF rarely go bad, but they do get dirt on them causing a code to be sent to the ECU. They can be cleaned of the dirt. try cleaning the MAF sensor. be VERY careful to not use much pressure on it. Use an alcholol cotton swab cloth, just drag the swab over it with no real pressure. get all around it all sides.. Again, be very careful with taking it out of the intake tube chamber, and be very careful with the fragile wire winding, cause it can break if you use too much pressure.
91 Legacy Sport Sedan 4eat
91crx si 165k
91crx Si 40.5k
85 BRAT Gl 140
97 SVX 74k
91crx si 165k
91crx Si 40.5k
85 BRAT Gl 140
97 SVX 74k
Brake cleaner also works for cleaning the MAF sensors
