A buddiy of mine has a 93 Touring wagon, and the turbo has locked up....could someone point me to a cheap replacement for it, or possiably a re-build kit for it.
He's not looking for more power, just something to replace the siezed one...
Thanks in advance...
Huck
93 Turbo Touring wagon question
[b]Huck[/b]
03 Impreza RS 5-Speed
89 XT-6 AWD 5-Speed Pearly (EG33 Powered aka FrankenWedge)
99 Forester S 5
94 Impreza Coupe
92 SVX LS-Tour RWD 5-Speed
99 Forester S 5
94 Impreza Coupe
I just replaced my turbo with a WRX turbo, so I have my stock one laying around. I don't know that I want to get rid of it yet, just in case, but if nobody else can help, hit me up. If I do decide to sell, I'd ask $75, just so you have an idea.
rebuild it if you can, its cheaper and it will last longer.
i got 5 vf-11 well 6 but ones on my car and it dont count. i got to stop shopping at the wreckers 3 turbos 100bucks how can you go wrong.
Where can he get a kit to rebuild it atNICO I WRX U wrote:rebuild it if you can, its cheaper and it will last longer.
I think that would be his best option too...
[b]Huck[/b]
99 Forester S 5
94 Impreza Coupe
99 Forester S 5
94 Impreza Coupe
rebuild kits for RHB5 / VF11 turbos run about $90 or so. You can buy 'em on eBay, if you don't have a local turbo shop to sell you one.
As long as its a bearing problem, the rebuild should fix it. But if your turbo has seized as a result of turbine or compressor wheel blade/housing clearance issues, the rebuild kit will be a waste of money.
If you end up with a rebuild kit, you will need a set of snap-ring pliers to get the first bearing out.
-Chris
91SS 4EAT stock, 200k mi
