Fronts:
Comparison:
New, Old (GR-2's, FWD springs, Stock topmounts)
Non-inverted:
Inverted:
Couldn't change the top mounts in the rear yet, so that's for tomorrow,
This is how it sits with the new stuff in the front, and an assload of shit in the back with AWD rear GR-2's, springs, and top mounts:
Kinda dark, but it was late. I'll take new pics when the rear is in tomorrow hopefully
Rears with GD top mounts:
Comparison of the top mounts:
Bolt spacing (didn't really take a good pic):
Rubber dealie:
http://www.thawa.net/gallery/soobys-suspension/IMG_0010
old and new
Comparison of the whole strut with 93? top mounts:
How it sits now with the same amount of shit in the trunk:
Plus I got this number goin:
Finally
Update #1
Well, the more I drove it, the more it felt as if the car was overdampend. The springs are just too soft for the struts. So I decided I needed to change that up. I ordered some of these badboys:
JDM STi Pinks.
They are tapered to the same diameter as the 90-91 Legacys.
Left = 90-91 top mounts, Right = 92-94 top mounts
The rear's are a little taller when not mounted.
The fronts are about the same height when not mounted.
This is how the car sits now.
That is exactly how I wanted it to sit. Evenly. Prodrive makes their springs for asthetic appeal. STi makes their springs for performance. Lowering a car unevely != performance. They're quite a bit stiffer too. You can totally feel it too. The rates are 45/38 N/mm F/R or 257/217 Lbs/in. The car rolls very little now, and the rears seem to lose their progressiveness fairly quickly. Which is a good thing. I haven't been able to romp on them yet, but I'm quite happy with it so far.
Fender-hub measurements:
Front: 343mm-50mm drop
Rear: 311mm-53mm drop
Anyway, just updating.
Even More pics here: http://www.thawa.net/gallery/soobys-suspension
Update #2
Well guess what. JDM STi Pinks still felt overdamped. So what to use?
STi Tuned by Arai springs. Or in reverse engrish:
Some comparison pics:
How the car sits now:
The spring rates are supposedly 60/50 N/mm Front Rear, or 343/286 lbs/in front/rear. They are supposed to lower a GDB 15mm which is 5mm less than the v8 pinks they just replaced. I only drove a few miles, but the car feels even better than before. I'll take some side pics and measurements once it settles.
Drove around about a week. Holy hell! With the pinks it would rub quite easily with nothing in the trunk. With the Arai's, nothing with a trunk full of shit. an extra 14mm of height and stiffer springs makes a big difference. There isn't as much weight transfer when shifting and braking either. The struts still feel overdamped at times, but better than before. Overall much better. Worth the money, but would've been worth it even more if I didn't buy pinks.
Front: 356mm-37mm drop from stock
Rear: 325mm-39mm drop from stock
Then again I did add these also:
And some more pics here: http://thawa.net/gallery2/v/thawa/sooby/suspension/
