what other car manufacturer's rims fit?
starkiller
have a 96 outback and going to the junkyard to find some cheap rims, i know some make's have the 5x100 pattern but is there a list showing those with the model and year for the correct offset?
thanx!
thanx!
"come to the darkside, we have cookies"
"the avalanche has started, it's too late for the pebbles to vote"...J.m.s.
starkiller
- quasi-mod-o
You can find 5 x 100 wheels. The big issue you'll run into is offset. Most of those wheels are going to have +35mm offset.
Subaru runs between +50-55mm of offset on their wheels.
Increasing scrub radius does increase torque steer quite a bit, but to tell you the truth, I haven't really noticed it.scottzg wrote:Word on the street is that going with less offset will increase torque steer and stress your wheel bearings.
I have enough power to break traction and still haven't noticed significant torque steer. That's on 225/45/17's on a 17x7.5 ET48 rim.
Well, scrub radius is the distance from center line to KIA, right? So I suppose a wider rim does reduce that distance, eh?
That's close (enough) to the proper offset for a 7.5" wide rim.BAC5.2 wrote:I have enough power to break traction and still haven't noticed significant torque steer. That's on 225/45/17's on a 17x7.5 ET48 rim.
Saab wheels will fit, well ones off the 9-2X. That's pretty much the only one I know of. If any other ones fit it will be from some uncommon car.
[url=http://img254.echo.cx/img254/5309/pond8fq.jpg]2000 2.5RS[/url]
starkiller
Does anyone have Scion wheels/tires up and running? They look pretty sweet and I'm guessing there is going to be a flood on the market at some point.
Check out the pic at the bottom of this auction.
http://cgi.ebay.com/ebaymotors/Subaru-L ... 9643QQrdZ1
