As the topic sais, i'm looking for some guidence on how to wire this sucker.
I've got several wires strung at the moment but I'm having trouble deciphering which one goes where.
1. fusible link from battery to inside cabin
2. Wire conected to low beams for power on to the relay
3. ground
4. wire to the fog lamp
This is where i'm getting my wiring info, but I'm baffled as to what goes were. I've got a 4 post relay, and this is where I'm getting my foglight info, it's at the bottom under wiring diagrams and electircal page .84.
Any suggestions?
http://www.driftquebec.com/legacy/1992_legacy.pdf
Has anyone used a JDM foglight switch?
04 modified XT
99 LGT Limited
99 LGT Limited
dscoobydoo
Ok, my guess based on most standard subaru wiring ( for the switch):
One wire from high beams for the switching off,
one ground,
one switched power
one for interior lights power light
one out to fogs
NOW, what I would do is this:
Run your own relay - power off an accessory point so the fogs work independant of the lights, but turn off when the car is off. ( try tapping into the cigarette lighter or stereo)
Use the fog switch, and power into it (and hook up the interior light to it by pulling off one of the nearby switches). That way you will be using 4 of the pins.
With a multi-meter, you can figure out which post is which.
If you decide it's too much hassle, sell me the switch.
one ground,
one switched power
one out to fogs
Yes I have too many Subarus
No you can't have one
05 GD-STI
01- RS- Swapped-07 STI
00- GF
05 GD-STI
00- GF
