swaping EJ20T heads on a EJ22t? what problems?
ej22t kid
Post by ej22t kid »
i am looking to get a little more power out of my 91 legacy turbo, i have read most of the conversation about the RS heads but was told those would not work because they are none turbo. i live in cali and have a couple of JDM engine importers around and can buy a EJ20t for around 650. would it be better worth the RS or EJ20t heads?
tris91ricer
Title Whore
Post by tris91ricer »
IIRC, Matt Monson recommends the NON-Turbo heads, EJ22E. Have you budgeted for that EJ20t, yet? If so, snag the 22E heads, and get some work done on 'em.
[b]'92 L Sedan[/b]
EJ20g 4.11 5sp LSD
[/quote]
Matt Monson
Post by Matt Monson »
Actually,
I think the Ej20G heads on an Ej22T would be a pretty potent combination. I sold mine to VRG for him to put on his car. And especially if you can get the complete engine with intake plumbing, AWIC, and if the engine came from a manual car the VF-8 turbo.
To do this swap, you would use the intake manifold from the EJ20G as well. Pretty much all the sensor connectors like IAC are the same. It should work pretty well on your stock ECU, but you will want to up the boost. the larger combustion chamber volume of the EJ20G heads will drop your CR to around 7.3:1 Not really a problem, but many people shy away from this because they think driveability will suck. This just isn't true.
The one custom piece to this swap would be mounting up your coil onto the manifold to use your stock ignition. But even that is pretty straightforward.
Lastly, using the RS heads is a decent option, but since they have no oil or coolant returns, a lot of custom work comes into play. The real beauty of the EJ20G heads is it really is a factory conversion...
2000 2.5RS daily driver.
1999 2.5RS w/ 50+ extra whp
Suby Hai!
tris91ricer
Title Whore
Looks like you got your answer, and I've got my facts straightened out. It's allllll good. :D
[b]'92 L Sedan[/b]
EJ20g 4.11 5sp LSD
[/quote]
Project_Legacy
Post by Project_Legacy »
sounds sweet. most likely my next project. when i get some damn moneys. :evil:
00 5MT AWD 2.5 RS - New Project
morgie
Post by morgie »
ej20G heads don,t have the same volume than ej20k-5-7 .. something like 46cc vs 49cc. that's little but that may be important.
morgie
'98 4Runner V6 Manual 4x4.
Project_Legacy
ej20g heads are easier and cheaper to get though arent they? :D
Matt Monson
Morgie,
Ej20G heads have a combustion chamber volume of 57cc. They are a fair bit larger than the EJ205, etc because of the old valvetrain design. They valves were tilted at a significantly wider angle than the vavles on other Subaru engines, and as such, they got more head volume.
Thank you for catching my error above. I said 7.3:1, that's for Ej25 heads. The EJ20G heads are going to put you at 6.8:1...
Suby Hai!
Natoe
Post by Natoe »
so for a cheaper alternative, the EJ22E heads are good as well? and there isnt a problem with coolant and oil lines?
sorry for my lack of knowledge but the EJ22E is all impreza and legacy NA 2.2L's?
thanks
Matt Monson
Nope,
There are no coolant or oil lines. The Ej22E heads just have a bigger valve size, but you would have to deal with coolant and oil for your turbo...
Suby Hai!
Legacy294
Vendor
Vendor
Post by Legacy294 »
DOHC heads will work, but as mentioned previously, match the intake and heads accordingly. Going with any of the SOHCs would be more of a lateral manuver.. :)
That set up is going into my rally car, ala 22B.. :twisted:
'96 GF/STi Rally wagon, under construction
If it's mechanical, it WILL break...
www.allwheelsdriven.net
Legacy294
Vendor
Vendor
Post by Legacy294 »
Matt,
since you seem to be sharp on the C/R equations, what would an N/A EJ22 w/ DOHC 2.5 RS heads end up with? We are contemplating that set up on a 2.5RS gone wrong.. :x My buddy (excellent engine builder) seems to think that the CR will be WAY too high and detonate like hell due to the flat top pistons in the 2.2NA.. what do you think? Have you built one?
Matt Monson
Legacy294 wrote:DOHC heads will work, but as mentioned previously, match the intake and heads accordingly. Going with any of the SOHCs would be more of a lateral manuver.. :)
I hope you aren't including EJ25 SOHC heads in that comment. The Ej25 SOHC heads are superior to both DOHC EJ205 and Ej25 heads...
Suby Hai!
Matt Monson
Legacy294 wrote:Matt,
Actually, if I read you right, your buddy has it backwards. The Ej25 heads have more volume than the Ej22 heads. You hit a very boost friendly 8.6:1 with that combination. I have one of these ready to assemble in my garage. I just need a gineau pig to let me put it in their car and see how much boost it takes to blow it up...
Suby Hai!
PeteGLH
Post by PeteGLH »
If I read correctly, EJ20G Heads would require a matching Intake manifold?
Would my stock Ej22T Exhaust headers bolt-up to the EJ20G heads?
- '91 Legacy SS 5MT (15,682 @ 86.47 @ 8 psi) Run with I/C, TD04 and 10 psi pending....
- '01 Toyota Corolla S (16,64 @ 84.34) Slow... but 30 mpg :)
Project_Legacy
i believe it should. i could check though.
That's correct, Pete. And yes, they would.
Re: ;)
PeteGLH wrote:If I read correctly, EJ20G Heads would require a matching Intake manifold?
yes on both counts
