When you light compressed air on fire...
LaureltheQueen
- Spelling Nazi
If you spray a can of compressed air into something(like a shotglass or a pop can) and then light it on fire, it makes this horrible gas. Sorta smells like chlorine.
What is it?
Avoid breathing it at all costs, your nostrils will feel like they're bleeding.
What is it?
Laurel Tuning Stage 15
92 Touring Wagon 5MT 16G
Why did you light compressed air on fire?
Arent a lot of them just compressed CO2?
Agh! That's probably phosgene gas!
Most "compressed air" cans are actually tetrafluoroethane. That is, R-134a. When R-134a is exposed to a flame it burns into, among other bad things, phosgene, which is really bad for you to breathe or even touch.
Don't do it!
Don't do it!
Yeah, real compressed air is just that - compressed air. You can use it to put out small fires by blasting it.
be VERY careful not to ignite R134a gas; phosgene is a common and large byproduct of the burnoff. Unless you want to experience effects similar to that of mustard gas, you'd be best off using the stuff to dust your keyboard and nothing more.
Enjoy.
Phosgene Oxime (CX), is a blister agent that operates similarly to the various types of mustard gas. It is a white crystalline powder which melts between 39 and 40° C and boils at 129° C. It has a high vapor pressure and has a highly irritating and unpleasant odor. It is, however, chemically unstable and decomposes quickly at high temperatures.
Phosgene affects the eyes, skin, and respiratory tract. It causes corneal lesions and eventually blindness, and when inhaled, causes pulmonary edema. It is highly destructive to human skin, causing irritation that is said to be highly similar to that of stinging nettles, but far worse. Even a few milligrams applied to the skin cause irritation, intense pain, and eventually a necrotizing wound. Few chemical compounds are known to be as destructive to human tissue.
1. Has the oder of newly mown hay and becomes a gas at 47 degrees F. It damages primarily the lungs. It must be inhaled to cause this damage.
2. At high concentrations, the chlorine part of the molecule irritates the eyes, nose, and upper airways. It may cause fatal layngospasm.
3. The real damage is done by the carbon, double bond oxygen group (carbonyl group) of the phosgene molecule. Causes severe, although not immediately apparent lung damage.
4. Phosgene is a common industrial chemical. Formally used as a chemical warfare agent. After phosgene is inhaled, the carbonyl group combines with the components of the membrane dividing the alveolus from the capillary. Fluid leaks from the blood into the alveolar septum, and then to the alveoli themselves.
5. Dyspnea at exertion worsens to dyspnea at rest. This is accompanied by a productive cough, producing clear, frothy sputum. The fluid loss after severe exposure can be as much as 1 - 2 liters per hour.
There are two major components to the physical effects of phosgene exposure leading to hypotension and hypovolemia.
a. Hypoxia caused by the fluid filled alveo.
b. Fluid loss.
Enjoy.
#82 M4 TRSCCA Rallycross
LaureltheQueen
- Spelling Nazi
Manarius
But who actually follows that rule except Chemists and Chem teachers?dzx wrote:yeh, in chemistry, your never supposed to smell anything directly, you just use your hand to wave a tiny bit in front of your nose.
rallysam
I think there's some confusion in this thread about the difference between compressed air "as in a shop compressor", and compressed air "in a can". I remember settling a bet by reading the side of the can, and it turned out it was some crazy chemical like what VRG mentioned.
'00 Impr RS - sold
JasonGrahn
LaureltheQueen
- Spelling Nazi
JasonGrahn
tris91ricer
- Title Whore
schspeedster
Was cleaning a laser printer at work with a compressed gas duster spray (maybe called Blow-Off?) which was "environmentally safe". Used a vacuum cleaner next to the nozzle blowing to pick up the dust...
BOOOOMMM!!!!
The explosion blew the cover off the vacuum. No damage just scary. Propane or something was substituted for the CFCs.
BOOOOMMM!!!!
who knew playing with um.....air.... would be so much fun
2007 Ducati 800ss - Current
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru GL Wagon
1987 Subaru Loyale
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru Loyale
