G'day fellas,
I would like to start an discussion about Diesel Oils in Subaru Engines due noisy tappets & cleanness etc
What would happen if we use Diesel Oils in NA & Turbo Petrol/Gasoline engines?
Could Diesel Oils can ruin Catalytic Converter?
Could Diesel Oils makes the engine to run hotter than normal oils?
What is the Pros and Cons on using Diesel oils in Subarus (on NA & Turbos)?
Thanks guys
AP
Diesel Oils in Subarus? Pros & Cons
alpineraven
Owns 1995 Liberty "Rallye" Sedan - NA 5MT AWD EJ22
