here is the link to my wreck info and the pics of smashed legacy turbo wagon parts. will update more later
http://www.jdmuniverse.com/forums/showt ... ge=1&pp=15
look at page two for subie smash partshttp://www.jdmuniverse.com/forums/showt ... post540920
smashed parts wreck pictures link to pcitures
91 Legacy Sport Sedan 4eat
91crx si 165k
91crx Si 40.5k
85 BRAT Gl 140
97 SVX 74k
91crx si 165k
91crx Si 40.5k
85 BRAT Gl 140
97 SVX 74k
LaureltheQueen
- Spelling Nazi
yesterday i replaced the door with one of the same color (43 bucks at the local JY). it was off a regular legacy wagon, non-turbo, and the wiring for the door is different. The regular leg had a connector, but the turbo wiring has no connector at the hinge. So I had to pull out the wiring from my old door, and put it in the new door. Also had to switch the upper window molding/strip, as the turbo is black and the regular is chrome, same for the outside handle. The color match from the used door is perfect, i will post pictures later. switching the window glass is a real B*tch.
The main damage was not the door though, it is the center lower radiator support frame. It is really bad, but not noticeable unless you look under the front. then you can tell how hard I hit the rebar. Still looking for a driver fender to switch to mine, it has to be same color. The car I got the door off of has both fenders smashed, so will have to wait til another comes along. My local JY has at least 15 legacy there, with lots good parts. I am willing to pull off and obtain anything that can be shipped, meaning smaller, non-bulky, non heavy things.
91crx si 165k
91crx Si 40.5k
85 BRAT Gl 140
97 SVX 74k
91crx si 165k
91crx Si 40.5k
85 BRAT Gl 140
97 SVX 74k
