95 Legacy EJ22 swap into 90 Legacy
subaruman
Post by subaruman »
I have a 90 Legacy in excellent condition except for the drive train. I have a wrecked 95 Legacy with a good engine and tranny. Would I see any problems with swapping the motor? Looks like I might have to change out the intake and then the rear diff to keep the ratios the same??? Any advice is welcome.
Thanks,
Jeremy
1984 GL Wagon D/R 4x4 EA81 (185k)
1990 Legacy Sedan L+ AWD Auto (160k)
Just swap the heads and block in and reuse the rest of the original engine.
subaruman
Post by subaruman »
So the intakes from the two cars won't bolt up? Diffrent port layout of the heads?
Jeremy
They should, but I don't know about sensor compatibility. If you just swap the whole deal over (intake, injectors, etc. as they can be removed as a piece) you won't have to worry. However, they may be the same anyway.
Isn't the 95 a single exhaust port engine?
Also, the 95 has an EGR valve......So you may run into more complications there.
