I saw on Nasioc that Matt has a Legacy Turbo harness for sale. He mentioned that it could be used for swapping. That got me thinking...
I was planning to do a standard WRX swap in the future. But if there is a certain engine or head/block combo that will work with the factory SS wiring with just an ECU swap, I'm totally open for that.
I can do the wiring for a WRX swap, but am certainly not looking forward to the untold hours it may take.
So, is there a early engine or such that makes an SS-->DOHC swap easier?
Jess
92 l swapped to ej22T with 2.0T shortblock
4.111 manual 2.5RS tranny, sti eng mount, wrx I/C, MBC, WRX turboback exhaust, WRX front seats, STI rad cap, WRX specR1 struts, Eibach springs , leg turbo front brake, WRX rear brake.
Well, it got dug up by somebody. I'm glad it did, because I just learned something new.
Anybody got links to a V1-V3 wiring diagram to compare?
Jess
probobly more common is the 89-94 JDM Legacy EJ20g. Most that I have seen are from the GT. But deffenitly try to find one from an RS or WRX(bigger turbos)
napphappy wrote:probobly more common is the 89-94 JDM Legacy EJ20g. Most that I have seen are from the GT. But deffenitly try to find one from an RS or WRX(bigger turbos)
I forgot the most obvious ones, ahh idiot
Amature move man!!
