the impreza based cars use totally different looking starters than the legacy uses.
my question is which starter would a guy use on a SS if he put a RS transmission and rearend in?
which starter? Legacy v. Impreza
greg donovan
96 Impreza L sedan
97 legacy outback limited
00 Impreza RS sedan
00 Impreza RS sedan
One meant for an RS
greg donovan
thats what i figured but i would hate to assume the wrong thing.Legacy777 wrote:One meant for an RS
are the legacy and impreza transmissions that different then?
the 4eat starter engages on the ring gear in the torque converter and the starter on a 5mt engages on the flywheel. correct?
96 Impreza L sedan
00 Impreza RS sedan
00 Impreza RS sedan
You want to use a starter for the specific transmission you use. The newer transmissions don't have the stud in the transmission case for the starter. I think it's two bolts.....I may be wrong, but I know it's different.greg donovan wrote:thats what i figured but i would hate to assume the wrong thing.Legacy777 wrote:One meant for an RS
You're correct about the engagement point for the starter.
greg donovan
both types of starter have holes in them so a stud and a bolt or two bolts shouldnt matter. the big difference that i can see is that the impreza starter has a "nose"Legacy777 wrote:You want to use a starter for the specific transmission you use. The newer transmissions don't have the stud in the transmission case for the starter. I think it's two bolts.....I may be wrong, but I know it's different.greg donovan wrote:thats what i figured but i would hate to assume the wrong thing.Legacy777 wrote:One meant for an RS
while the legacy starter doesnt have that nose covering the gear. and the legacy starter is a reduction drive type starter.
96 Impreza L sedan
00 Impreza RS sedan
00 Impreza RS sedan
