EJ22 and EJ22E?
EJ22 and EJ22E?
What is the difference between these two engine types or is there?
1993 Legacy L sedan
-Blacked out trim and grill
-DIY grounding kit
-Ground Control Coilover conversion
-GR-2 Struts
-De-snorked
-My Dream: Install an Eaton M62 Supercharger.
-DIY grounding kit
-GR-2 Struts
-De-snorked
EJ22E - 2.2 Naturaly Asprirated
EJ22T - 2.2 Turbo charged
The EJ22T is a different block than the EJ22E in several ways but when most people refere to the EJ22 they are probably refering to the EJ22E.
Lee
- Title Whore
i love the coilovers. There is about 2" maybe 2.5" of adjustment up or down in them. When they are all the way down the rear rides at about stock and the front sits a little more than 1" lower than stock. As far as how they ride i love em! A little springy but a hell of a lot of fun around corners. They were a solution to my body roll problem on turns. I cant imagine the handling that i would have with front and rear sway bars and 16" wheels. Plus you cant beat the price. I had the coil overs installed on KYB sturts. As far as ground control goes they are a good company, just expect them to take about two to two and a half weeks to get you the conversion kit, they are custom made to order. The only thing that i wish they had was a spring retainer so that the spring does not go free is one strut goes fully extended. If you want a coilover setup like that you are talking like almost $1700 for sturts and springs! All totalled up mine was a little more than $800 for struts and springs. If you are interested you should call up Bugaid in Shorline, thats who I had do mine.
1993 Legacy L sedan
-DIY grounding kit
-GR-2 Struts
-De-snorked
-DIY grounding kit
-GR-2 Struts
-De-snorked
