Ah, my Kingdom for a set of rebuilt heads.
Posted: Sun Sep 18, 2005 3:00 am
by douglas vincent
I couldnt take it anymore and started rebuilding my wifes old block. Threw in my old 1000 mile pistons and rings, newer oil pump and front main seal and then got stuck. I have SIX sets of heads. None are good enough to trust. Damn.
Re: Ah, my Kingdom for a set of rebuilt heads.
Posted: Mon Oct 03, 2005 7:19 am
by bmxpunk
douglas vincent wrote: I have SIX sets of heads. None are good enough to trust. Damn.
:shock: :shock: :shock: 6 :shock: :shock:
Posted: Mon Oct 03, 2005 2:10 pm
by skid542
What kind of heads are you looking for? I can pull the heads off my old NA as I think the only damage it had was to the bottom end.
Posted: Mon Oct 03, 2005 6:48 pm
by douglas vincent
They are all fine, they just need a rebuild and clean up. Just dont have the extra $150 right now.
Posted: Tue Oct 04, 2005 1:11 am
by douglas vincent
Well, today, I picked up the set of heads I had rebuilt. I also picked up the head I THOUGHT was cracked in the exhuast port. It was fine. So there are some serious questions about why I was blowing air into the cooling system.
I think I am going to have a set of turbo heads rebuilt and use those, but swap out cams and change the valve covers to NA covers, and exchange the rear oil feeder on the passenger side head. This way I can use turbo head gaskets and not have to chop them up.
Wagon should be driving tommorrow. Cross your fingers.
