Junkyard AXLE?
Alvaro Alonso
Junkyard AXLE?
Post by Alvaro Alonso »
Hi everyone,
I am looking for a front axle here in Spain. The factory one will cost me 500$ aprox. To rebuild mine I've been told it will be 220$. And at the major Junkyard (well it is more than that, it is a decontamination recycling center) will be 21$ :D .
What do you think, do you usually buy those sensitive parts at the junkyard?
Thank you
__________________________
Alvaro
If you can examine it first to make sure the boots are in good condition, it seems okay to me. Axles usually only fail if a boot tears open.
You could afford to have the junkyard axle fail ten times before it approaches the cost of a rebuild.
scottzg
Post by scottzg »
might be a good idea to buy the jy axles with good boots, and then replace the boots.
Bheinen74
Post by Bheinen74 »
dont replace good boots with other good boots
91 Legacy Sport Sedan 4eat
91crx si 165k
91crx Si 40.5k
85 BRAT Gl 140
97 SVX 74k
greg donovan
Post by greg donovan »
junkyard all the way.
i know many rally drivers that use junkyard axles and they hold up just fine.
but, as others have said, make sure the boot is in good shape and not torn.
96 Impreza L sedan
97 legacy outback limited
00 Impreza RS sedan
Alvaro Alonso
Thank you everyone.
I will be getting junkyard one. I have a friend going to Madrid (5 hours drive) and he will pick it for me.
I hope it is not very difficult to remove/reinstall.
MY92
Post by MY92 »
Just get one from the yard and replace the inner cv joint if necessary.
John
http://www.cardomain.com/ride/560635
scottzg
Post by scottzg »
Bheinen74 wrote:dont replace good boots with other good boots
I had my car sit undriven for 6 months and when i drove it again, 3 boots popped within a week. I'd say this simulates what a jy axle does pretty well.
