Headlight automatic height wiring
Alvaro Alonso
Post by Alvaro Alonso »
Hi,
I got two new headlights from the junkyard and they came with this electronic heigth adjust feature.
I have the conectors to plug them to the headlights.
I also took the control switch for the interior panel, but to my surprise I don't see the conector wich is suposed to be there.
Has anyone done sort of this upgrade? will this connector be awaiting me to dissasemble the whole instrument panel?
Thank you
Are they for the pre or post face lift car?
Do the leveler motors have six or 3 pins on them?
I put the pre face lift lights on my car.
http://www.main.experiencetherave.com:8 ... dmproject/
THAWA
Post by THAWA »
can you find another set for me?
Alvaro Alonso
I could try, but consider I am in spain and you would have to pay transport (if just the adjusting motors it wont be very much), from the junkyard to home and then packing to USA.
what do you want me to ask? complete headlights or just motors?
Alvaro Alonso
Hi Josh,
yes they are EDM pre face lift, same as yours, as for pin count, I'll tell you later.
I had to verify all the wiring myself, and haven't done my write-up yet :(
But when I get back from my vacation, I can hopefully scan in my hand drawn diagram.
Alvaro Alonso
I've gone to the garage and found the conector :) under the steering weel. Just pushed upwards and conected to the switch.
The conectors are 6 pins. All works fine now unless for.........
my right headlight is not motorized, i took 2 headlights one ok and one broken, hoping to make it fit.
I removed the mechanical adjust system and inspected it but it seem quite different to the electrical one. They are not directly interchangeable :(.
so i'll try to get an entire electrical headlight since i have mine quite damaged.
Is there any way to get the cristal cover out of my assembly and fix it to the broken one? it has some sealing in it and won't came off easyly.
tris91ricer
Title Whore
Post by tris91ricer »
Bake it in the oven?
I did it once, and it was alright... Just pry gently.
[b]'92 L Sedan[/b]
EJ20g 4.11 5sp LSD
[/quote]
Alvaro Alonso
Well I will try that, after I know what to use then to replace the sealing :D. Any Clue?
tris91ricer
Title Whore
RTV? Silicone-based something. Another note, heat your oven to 170*F, don't wanna cook 'em, just heat 'em up. Otherwise, a heat gun works just as well...
[b]'92 L Sedan[/b]
EJ20g 4.11 5sp LSD
[/quote]
THAWA
Post by THAWA »
Complete headlights with switches and relays and whatever else. I don't care about shipping costs.
Alvaro Alonso
Hi Thawa,
I have found only 92 manual adjust headlights at 60€+60€+shipping+international shipping.
