Headlight automatic height wiring
Posted: Tue Sep 20, 2005 1:43 am
by Alvaro Alonso
Hi,
I got two new headlights from the junkyard and they came with this electronic heigth adjust feature.
I have the conectors to plug them to the headlights.
I also took the control switch for the interior panel, but to my surprise I don't see the conector wich is suposed to be there.
Has anyone done sort of this upgrade? will this connector be awaiting me to dissasemble the whole instrument panel?
Thank you
Posted: Tue Sep 20, 2005 3:20 am
Are they for the pre or post face lift car?
Do the leveler motors have six or 3 pins on them?
I put the pre face lift lights on my car.
http://www.main.experiencetherave.com:8 ... dmproject/
Posted: Tue Sep 20, 2005 4:57 am
by THAWA
can you find another set for me?
Posted: Tue Sep 20, 2005 8:24 am
by Alvaro Alonso
I could try, but consider I am in spain and you would have to pay transport (if just the adjusting motors it wont be very much), from the junkyard to home and then packing to USA.
what do you want me to ask? complete headlights or just motors?
Posted: Tue Sep 20, 2005 9:18 am
by Alvaro Alonso
Hi Josh,
yes they are EDM pre face lift, same as yours, as for pin count, I'll tell you later.
Posted: Tue Sep 20, 2005 1:54 pm
I had to verify all the wiring myself, and haven't done my write-up yet
But when I get back from my vacation, I can hopefully scan in my hand drawn diagram.
Posted: Tue Sep 20, 2005 4:36 pm
by Alvaro Alonso
I've gone to the garage and found the conector
under the steering weel. Just pushed upwards and conected to the switch.
The conectors are 6 pins. All works fine now unless for.........
my right headlight is not motorized, i took 2 headlights one ok and one broken, hoping to make it fit.
I removed the mechanical adjust system and inspected it but it seem quite different to the electrical one. They are not directly interchangeable
so i'll try to get an entire electrical headlight since i have mine quite damaged.
Is there any way to get the cristal cover out of my assembly and fix it to the broken one? it has some sealing in it and won't came off easyly.
Posted: Tue Sep 20, 2005 7:38 pm
by tris91ricer
Bake it in the oven?
I did it once, and it was alright... Just pry gently.
Posted: Tue Sep 20, 2005 10:58 pm
by Alvaro Alonso
Well I will try that, after I know what to use then to replace the sealing
. Any Clue?
Posted: Tue Sep 20, 2005 11:28 pm
by tris91ricer
RTV? Silicone-based something. Another note, heat your oven to 170*F, don't wanna cook 'em, just heat 'em up. Otherwise, a heat gun works just as well...
Posted: Wed Sep 21, 2005 2:31 am
by THAWA
Complete headlights with switches and relays and whatever else. I don't care about shipping costs.
Posted: Thu Sep 22, 2005 10:46 am
by Alvaro Alonso
Hi Thawa,
I have found only 92 manual adjust headlights at 60€+60€+shipping+international shipping.
