bad coolant temperature sensor side effects?
greg donovan
Post by greg donovan »
just replaced my failed coolant temperature sensor. the car threw a code for the CTS and knock sensor.
the car would barely start when it was cooler out (65-55 deg.) and would run like crap untill the engine temp gauge got in the middle.
it would start then die. or not start at all. and it wouldnt hold an idle and if you gave it gas it would stall out.
this will cause the engine to run lean or rich depending on if the CTS was reading too hot or too cold, correct?
could a bad CTS hurt my mpg?
96 Impreza L sedan
97 legacy outback limited
00 Impreza RS sedan
Richard
Post by Richard »
Mine had the same problems with mine. Crappy idle, holding my foot to the floor to start it, crappy mileage, less boost, fuel cut and retarded timing. I noticed an immediate difference when I changed my CTS. The guy at Checker didn't believe me when I went to buy the new sensor. I came back and enlightened him on how dependant ecu's are on their sensors. He said he was a small block Chevy guy and thanked me for the info. I'm sure the next guy to come along with a similar problem will be better off.
What is a mog?
greg donovan
Richard wrote:Mine had the same problems with mine. Crappy idle, holding my foot to the floor to start it, crappy mileage, less boost, fuel cut and retarded timing. I noticed an immediate difference when I changed my CTS. The guy at Checker didn't believe me when I went to buy the new sensor. I came back and enlightened him on how dependant ecu's are on their sensors. He said he was a small block Chevy guy and thanked me for the info. I'm sure the next guy to come along with a similar problem will be better off.
What is a mog?
cant type to save my life some days. stupid tiny laptop keyboard.
96 Impreza L sedan
00 Impreza RS sedan
Richard
Post by Richard »
Ah, miles per gallon. The bad CTS hurt mine. Sucker reeked of unburned fuel alot. This site has saved me a lot of trouble. Much thanks to everyone. Be sure to reset your ECU.
greg donovan
well there hasnt been much of a mpg increase. still at about 100 miles at half tank just like before.
96 Impreza L sedan
00 Impreza RS sedan
