Anyone have a tip or technique they use with good success to identify an exhaust leak.
I'm pretty sure that I have one because I can hear an exhaust sound (while driving) that sounds like it is coming from near the front catalytic converter/y pipe. But when I get under the car it is hard to id by sound because of the engine noise and typical exhaust sound coming from the muffler.
Identifying an exhaust leak
1987 VW Westfalia Vanagon - EJ22T Powered
1994 Legacy Touring Wagon
If you feed the engine some Sea Foam the exhaust will be very visible because of the smoke.
Also, if you cover (or partially cover) the tailpipes with the engine idling, more exhaust gas will be forced out the leak.
legacy92ej22t
Haha, this is exactly what I was going to suggest too.vrg3 wrote:If you feed the engine some Sea Foam the exhaust will be very visible because of the smoke.
Sea Foam rocks.
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
