I have a set of turbo rotors I'd like to have turned. Anyone know minimal thickness and runout specs for turning them?
A
SS Brake machining tolerance and runout
ACP
www.musketeerracing.com
1991 Legacy SS 5MT Rally car (sold)
1993 Legacy SS 5MT Street car (selling)
1997 Lancer Evo IV RS Rally car (sold)
2006 Lancer Evo IX RS Rally car
2009 Lancer Evo X RS Rally car
1989 240SX SR20 Drift car
look on the disk. the minimum thickness is almost invaraibly stamped on the center near the lug holes
you should allow that 0.030" or so will be removed in re-machining
runout should be 0.005" or so or less
basically if you can see it wobble, its no good
machining a warped rotor gives you a machined, warped rotor; it will never hold up for long
Aha! So they are. The fronts were so corroded on the backside that on a casual glance I hadn't seen the writing. 22mm on the front and 16mm on the rear IIRC from 30min ago.
A
PS how much do you pay your local machinist for turning these?
A
ACP
ACP,
Typically the turbo rotors are too warped/ cracked to turn..
It would be best to just replace the rotors. They are pretty inxpensive for stock replacements, and will work much better for longer.
or you could upgrade to a slotted rotor for a bit more $.
'96 GF/STi Rally wagon, under construction
If it's mechanical, it WILL break...
www.allwheelsdriven.net
