Proof of the smaller exhaust valves of Turbo heads?
douglas vincent
Post by douglas vincent »
I have two sets of turbo heads. Neither looks smaller too me compared to the 4 sets of NA heads I own.
I set of heads is 93. The other is off of Brandos,
206er
Post by 206er »
so you measured the valves and NA are the same? are the ports the same size?
Matt Monson
Post by Matt Monson »
Yeah,
Did you measure them? I was the one who put that information out there, and it was because I measured them. The difference is +/- 1/16" IIRC. And I believe the ports are the same size.
But just look at the valves themselves if you don't have a caliper to measure them. The valves definitely have different casting stamps on them...
2000 2.5RS daily driver.
1999 2.5RS w/ 50+ extra whp
Suby Hai!
douglas vincent
Ok kids.
I measured two sets of turbo heads and two sets of NA heads.
Turbo heads have:
Exhaust 1.10 OD and are marked EX2S
Intake 1.22 OD and are marked lN1
NA heads have:
Exhaust 1.10 and are marked EX2
Intake 1.28 and are marked lN2
So we have two different sets of marked valves, although the exaust valves ARE THE SAME, but we have a 1/16 bigger intake valve on the NA heads.
As for the ports, I do not know.
Matt Monson
http://bbs.legacycentral.org/viewtopic. ... rent+heads
Well, not the first time I have gotten confused around here. I had it right the first time, but somewhere along the line someone (and it could have been me) got intake mixed up with exhaust, and it became urban myth...
Suby Hai!
douglas vincent
I wasnt accusing you.
Interesting.....that blows the smaller exhaust valve, more exhaust velocity theory out of the water.
So what effect does the smaller intake have? Maybe to limit power....
Improved low end torque?
nzKAOSnz
Post by nzKAOSnz »
rememeber than a turbo is called forced induction for a reason, and even with a smaller inlet valve - will flow more through into the cylinder.
Im thinking it might have something to do with improving the top end of the rev range for the turbo (less mass so less chance of valve skipping), whereas a NA needs more air because it has to suck it in.
***ITS CLEAN! :D*****
Matt Monson
douglas vincent wrote:I wasnt accusing you.
I didn't feel accused. I just wanted to own that I may have mixed people up.
Legacy777,
I don't know why this would throw out the port velocity idea. To my thinking, it actually supports it, and it going to lead to the crisp low end torque the Ej22T is known for...
Suby Hai!
I was meaning it throws out the exhaust port velocity theory. The only way I can see it have any affect is in the cylinder scavenging....
musketeerracing
Post by musketeerracing »
Soooo, you might recall that I bought this SS and it turns out to have an open deck EJ22 block but I've measured the valves and the heads appear to be turbo.
I have the option of putting the engine back together with the turbo heads or the NA heads that I also have. I suspect I'll have a larger turbo soon too, and other mods.
So, what's the opinion out there on intake valve size? Is bigger better? Is the NA intake:exhaust valve size ratio inferior to the turbo valves? Was it maybe an emissions thing, or engineered to 8lbs of boost, or to provide longevity on certain fuel ie all things we don't care about?
Or does it matter?
A.
ACP
www.musketeerracing.com
1991 Legacy SS 5MT Rally car (sold)
1993 Legacy SS 5MT Street car (selling)
1997 Lancer Evo IV RS Rally car (sold)
2006 Lancer Evo IX RS Rally car
2009 Lancer Evo X RS Rally car
1989 240SX SR20 Drift car
