side-exit exhaust
side-exit exhaust
I'm wanting to do a side-exit exhaust, probably 2.5" to 3" max (turbo engine).
coming out right infront of the driver or passenger side rear tire. I'm not sure which is better or would look "right".
has anyone seen this/done this before, or does anyone have any opinions on it?
the idea is for straight pipes with a resonator to cut down on the raspy-ness.
Manarius
Do both. Run straight pipes out each side correspondingly with resonators (ie. don't combine the exhaust; however, fabricating that would be a real b!tch). I personally think it would look cooler if the pipes came out behind the wheels (and also you wouldn't have issues with heat right under the back door), but then you do have to deal with axles and what not. I would suggest however that if you get the mod on, get extensions that will aim the exaust down..you don't want black stains on the side of the car.
Also, you may want to take into consideration that if you were to go behind the tire, on the right side is the gas tank.
You suggest dual pipes on a turbo motor, without combining the exhaust? How?
I was going to have a cutout routed to the side, right behind the passenger side front wheel, but that would reduce ground clearance by a TON.
If you do it, stick with passenger side. Quieter for the driver, and less pipe.
Manarius
BAC5.2 wrote:You suggest dual pipes on a turbo motor, without combining the exhaust? How?
you can point a cutout right at the passenger front tire without it showing loud as all getout.
nothing sounds like a exwastegate dumped stright out. almost like a giant compressed air leak. well mostly because thats bascily what it is.
-jason
What would the point be, if your going to resonate it?206er wrote:yeah avoids going around the driveshaft and having it hang all low.
how big is a resonator for 3" exhaust?
I thought the point was to have the shortest possible exhaust travel path as possible, for best possible performance. Why ruin that with a resonator?
I don't think a side pipe on a Legacy would look "right" anyway.
Wouldn't they have to be like .75" in diameter to keep velocity to an acceptable level? It'd sound like an old bug.Manarius wrote:True dual exhaust on a NA engine would be the shit
Manarius
What would happen if you just got some low flow mufflers to keep up the pressure?THAWA wrote:Wouldn't they have to be like .75" in diameter to keep velocity to an acceptable level? It'd sound like an old bug.
I've never heard any noticeable problems from Lightning owners about the right side of their truck having tire problems.n2x4 wrote:What about abnormal tire heating from the exhaust gasses? (Thinks about the Ford Lightning Pickup)
I doubt it would be anything to be worried about. The 05 SRT-10 Viper has side exhaust right behind the driver door in front of the rear tires, and they don't have problems.
yeah the vipers dont have any problems, except for lighting themselves on fire after a track day becasue the carpet gets too hot over teh exhausts.
if you want shortest possible than just get a txs shorty thigh, weld half of a u bend to a flange, bolt up and have the end sticking out the side.
-jason
