Well, the genius that did my alignment that I got right after my wheel bearing project had my front camber at 0 dead on for the left and -0.4 for the right. I guess he thought I was going to be running NASCAR or something
Anyway, so when I did that yesterday, I didn't even mark anything. I just took it apart, swapped the mounts, reinstalled the struts and put the camber pretty close to where they were last time. I figured, I'm going to go straight to the alignment rack when I get to work, so what does it matter?
So, I had the guy put the car up there and set it all up, and ya know what my before camber settings were? Left :0 dead on, and right: -0.3!!! Is that pure luck or am I just that good??
I actually told the guy to set my camber at -0.2 on both sides, since I do take corners a slight bit faster than the average driver, and that isn't enough to wear anything out much faster.
