I'm good
Posted: Tue Oct 11, 2005 5:18 am
So I replaced the strut mounts on Patti this weekend. As we all know, by removing the struts, you lose the front camber settings, unless you mark them, and even then it's not quite accurate.
Well, the genius that did my alignment that I got right after my wheel bearing project had my front camber at 0 dead on for the left and -0.4 for the right. I guess he thought I was going to be running NASCAR or something
Anyway, so when I did that yesterday, I didn't even mark anything. I just took it apart, swapped the mounts, reinstalled the struts and put the camber pretty close to where they were last time. I figured, I'm going to go straight to the alignment rack when I get to work, so what does it matter?
So, I had the guy put the car up there and set it all up, and ya know what my before camber settings were? Left :0 dead on, and right: -0.3!!! Is that pure luck or am I just that good??
I actually told the guy to set my camber at -0.2 on both sides, since I do take corners a slight bit faster than the average driver, and that isn't enough to wear anything out much faster.
