WTF Mate?
LaureltheQueen
- Spelling Nazi
WTF Mate?
No passenger side firewall grommets? Is there a reason for this? My boost gauge is going to be mounted right under my radio, and it's a bit of a pita to run the line from the passenger side to the driver's side, to the middle of the car. Any easier way?
LaureltheQueen
- Spelling Nazi
Isn't the check valve in the booster hose? I suppose it doesn't matter if you tap after the valve.
Oh yeah, the check valve...
The check valve is like halfway through the hose; you can feel it if you squeeze the hose. You'd want to tap between the manifold and the check valve. It should be easy enough -- get a 3/8"-to-3/8"-to-1/8" vacuum tee. I've seen a few Legacies with that done in order to drive an aftermarket cruise control actuator.
LaureltheQueen
- Spelling Nazi
LaureltheQueen
- Spelling Nazi
LaureltheQueen
- Spelling Nazi
I used the hard line stuff wrapped in a vacuum line all through the engine bay, and had no huge problems with routing it. I'll likely continue to use it until I encounter a problem. The nice part is, It's skinny running through everything, and I'm not worried about it getting kinked as I would be with squishy vacuum line. And yes, I know if it gets kinked, it's more permanent than a kink with a soft vacuum line.
Laurel Tuning Stage 15
92 Touring Wagon 5MT 16G
